New injectors are on hold. Once I put them in I cant drive it anymore until it gets tuned again. My plan is to register first then upgrade injectors, turbo and boost controller. I installed a Walbro fuel pump already.
818S Chassis #288 2.5L 323hp
joshuajach.com
Alright alright you can beat me to making it street legal. Then I'll just do what you do![]()
Nolan
joshuajach.com
Looks good. Nice job!
Larry
Yeah the red and black together look really great, nice cut of colors.
joshuajach.com
Looking good. Congrats on the milestone. Are you able to go ahead with registration now that the body "shell" is fully in place?
I don't see any hood pins yet so I imagine he still has a bit to go. Considering that though, your body fits really well just laid in place! Our rear deck lid wants to pop up in the corners way more.
Tamra
First autocross 3/29/15
Red is great!
The red looks really good. I had ruled painting red out because my last 2 fun cars were red. But this has me re-thinking that.
Your body lines look great. I'll be very happy if I can get mine to line up as nice as yours does.
If those are the blue wrx injectors, you can grind off the restrictor plates on the end and get ~800cc. I did that and had them cleaned/flow tested. All were within 5cc at 824cc. My tuner didn't like them at first but I got a buttery smooth 318awhp 328awtq. (vf39, walboro 255lph,BC280 cams). I can get a lot more power but I had him limit the tune for the sake of the glass box. So far I have ~5k miles with no issues.
The top panels are just laid in place, waiting for Craig's hood hinges. Once the panel are all secured I'll try to get it registered.
I've trimmed my deck lid a bit to help with the corners popping up, they still pop up if you bump the car at all.
That is just the red gel-coat. It looks great in pictures and from a distance.
joshuajach.com
Got a couple nice features working this weekend. The Sparco steering wheel hub does not come with a workable solution for the horn. It does however have a contact ring, so I rigged up a custom solution using a Dorman pin http://www.amazon.com and a mechanical pencil. I'll find out how long this will last eventually.
The red piece is the shell of a mechanical pencil cut to size.
I glued these parts together so that the red part acts as support for the spring and wire.
Found a good location on the column and epoxied it in place.
With the Sparco Hub in place the the spring is slightly compressed, maintaining a connection during rotation.
joshuajach.com
Also fixed the turn signal so that it will auto turn off when exiting a turn. I used a small exhaust pipe I found at O'Reilly's and duplicated the OEM function. I was planning to weld the pipe to the sparco hub but I turns out the hub was non-magnetic, so I guess its cast aluminum. I got frustrated and impatient so I ended up with a bit of a hack.
The angle brackets aren't bolted to the hub, instead they are acting as a clamp.
joshuajach.com
Looking good!
Nolan
joshuajach.com
joshuajach.com
Nice looking handles. What are they off of? Do you have a link to the auction you got them from. I was personally looking at maybe doing GTR handles, I like the way that they pop out when in use plus it would be rice so it would instantly add like 15hp![]()
Thats 15hp per handle!
Left and Right were sold separately:
http://www.ebay.com/itm/371064017334...%3AMEBIDX%3AIT
http://www.ebay.com/itm/271493405643...%3AMEBIDX%3AIT
joshuajach.com
I need to modify my momo hub to flip the blinkers off after a turn. I think I'm following what you did, but any additional detail would be appreciated.
Anything special about that hazard light switch? I was thinking about ditching the oem Subaru one and putting in something like that.
You'll want a latching DPDT or DPST. If you want the switch led to blink with the turn signals you'll need an additional diode.
http://www.aliexpress.com/item/19mm-...909881091.html
I wired mine like this:
joshuajach.com
Hazard switch, really nice looking (handles too!), by blinking with the flashers, you mean every time you toggle a flasher it will blink the switch's light?
What you want to happen is this: When using the turn signal (left or right) the hazard button indicator light does not turn on. Only when the hazard button is pressed does the hazard light blink.
If you don't use the extra diode then the hazard button light will turn on when using the left turn signal.
joshuajach.com
I did something similar since I didn't like the OEM switch. I had to use a 3pdt relay (non-latching) and an after market hazard button. I did not wire the LED in the switch to blink I tied it with the dash lights so I can see it at night.
joshuajach.com
joshuajach.com
Texas is great, but Indiana doesn't inspect. lol.
I shipped your hood hinges out today at lunch. I'll send you tracking info.![]()
Zero Decibel Motorsports
joshuajach.com
Way to go Josh.
Spinning is good. If you never spin you're never trying to find the limit.
Installed Craig's hood hinges. It looks great unpainted and works great, anything to cut back on the hood pins.
Its an easy install, would have been easier if the front bumper wasn't in the way. I also think it needs a spacer between the bracket and the hood to prevent the hood from warping when bolted together. For now a bunch of washers will do.
Bondo is still drying.
joshuajach.com
Nice!
Tamra
That was quick. Lol.
Installed 550# springs on the rear. I'm wondering if the larger outer diameter is going to be a problem? The inner diameter is correct.
Also found my noise problem when going over moderately sized bumps. The flange that attaches the fender of the front bumper clips the wheels. I had trimmed this earlier, apparently wasn't enough.
joshuajach.com
joshuajach.com
