17
Finally another milestone. The body is on. All wiring tucked up and harnessed. Gosh I hope I didn't forget anything lol
A very helpful tip from Tony Zullo. To get body on and to spec as far as body opening dimension it was so simple.
Step rep one attach at firewall. Next get door sills mounted down and in all the way. Finally lift tail until you het the 45.5" dimension. Worked like a charm!
Nick Sebastian - 33 Hot Rod #495
Factory Five Forums - hdnik
FFCars - lowntubd
Build Site/Blog -
www.nicks33hotrod.com
