The oil pressure sensor on 302 SBF is on the DS just forward of the oil filter. The pressure sensor is too big to fit directly into the location because of the oil filter. A common problem solved by some with brass fittings but I wanted something stronger than brass for this critical part.
Summit sells a Scott Drake Oil Pressure Sending Extension (Part #SDK-C2OZ-9B339) made of zinc coated steel. Before installation it was treated with SharkHide. It came in 1/4" NPT at both ends and the sensor is 1/8" NPT so I had to add a coupler to make the transition.
Here is the final installation with the sensor wiring connected.
Carl
