Thanks for the info. I'm using parts from a 2006, so it's a later model. Any suggestions on where to obtain the wiring manual online?Mike, your cluster can be powered up by connecting 12V to pin C10 and ground to pin C6. I took a guess that you have a later model cluster but for the earlier ones it would be pins A10 and A6. Make sure you download the wiring manual for whatever year wiring harness and ECU you end up getting.
