0
0
Originally Posted by
mistasherm
Anyone know what is supposed to be attached to the actioning tab on the clutch cylinder? It looks like there should be a spring or something like that there to assist with pedal return but I don't seem to have it. Folks have told me that the clutch would return on its own? Running a 2004 WRX trans and I think that is the "push" fork set up.
When the clutch pedal is not connected to the clutch, the pedal's spring will toggle between fully depressed and fully released this is to aid in holding the clutch disengaged. Once everything is fully hooked up and the hydraulics are primed the pedal will function as expected. The return force will come from the clutch pushing back on the slave cylinder which in turn pushes the clutch pedal back to its original position.
Reason: more details
