Likes Likes:  2
Page 26 of 27 FirstFirst ... 1624252627 LastLast
Results 1,001 to 1,040 of 1079
Thread: MRG MotorSports 818S Build
  1. #1001
    Had the 818 apart to replace the engine. Just thought I'd post some pictures without the coves on.
  2. #1002
    Parts for Dry Sump System
    Getting ready for my dry Sump System.
    Waiting on my 2.5 gallon tank. I will order hoses and fitting once I have everything mounted in place.
  3. #1003
    USA
    Nice looking parts.
  4. #1004
    Edmonton, Alberta
    Gotta love shiny new parts! Is that a kit or DIY? Nice to see a few more cars getting dry sumps, definitely the Achilles heel of the EJ.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  5. #1005
    All those parts came from Aviaid, Plus I am getting a tank from them. aBOUT 1.8K for the parts so far.
  6. #1006
    Edmonton, Alberta
    An unfortunately expensive necessity, but as far a dry sumps go that's not a bad price. I'm hopeful I won't need one, but time will tell.
    818 SRX - #91
    Arrived 01/02/2014
  7. #1007
    That's what I said, before I my engine started making that bad sound.
    The time for me was 300 autocross runs and 7 track days.
  8. #1008
    working on dry sump
    Did some test fitting of my dry sump with some cheap equal length headers.
  9. #1009
    Bowling Green, KY
    Nice, what is the ratio difference between crank speed and pump speed?
  10. #1010
    The pump is a 5.5" diameter. I don't know what the crank is for sure, but it's about the same.
    I don't think the speed of the pump is that critical, as it is scavenge only.
  11. #1011
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Bob, when you did the bump steer kit, did you drill out the spindle or did you use the taper bolt?
  12. #1012
    I used the Baer kit that was a tapered stud.
    http://thefactoryfiveforum.com/showt...l=1#post239655
  13. #1013
    Dry Sump Pump mock up
    We mocked up our Aviaid dry sump install on my blown engine.
    My forester AC compressor bracket wouldn't work. Fortunately I had one off an Impreza:
    Attachment 58981
    Then mounted the Aviaid pump adaptor bracket.
    Attachment 58982
    Then Mounted pump: I choose holes based on easiest access to bottom fitting:
    Attachment 58983
    Then mounted belts. This belt is 2" longer than the original AC belt.
    Just noticed that the belt packages our on opposite sides.
    Attachment 58984
    Done:
  14. #1014
    Hindsight's Avatar
    Atlanta
    Thanks Bob - Are you running the 4.5" ride height? Have you settled on spring weights you are happy with front and rear? Looking at the post you linked me to, it doesn't look like you ended up being happy with the settings.
  15. #1015
    Hindsight,
    I'm at 5" RH until, maybe 4.5" with us sitting in the car.
    running 350f and 500r springs.
    I have a bunch of non spec suspensions changes. Don't go by my bump steer spacers.
  16. #1016
    Steel tubing for scavenge lines.
    Mike and I decided to use steel tubing on our dry sump scavenge line because they have to run close to the headers. This is our first time working with anything bigger than brake line. We actually used our harbor freight hydraulic pipe bender to bend the tubing.
    We will put the oem heat shields on the header. We are going to use 2000 deg fire sleeve over the tubing and hose under the engine. https://www.summitracing.com/parts/dei-010474
    Here is a picture of out mock up.
  17. #1017
    I used steel lines to my dry sump pan.
    I didn't want to take a chance of melting a hose.(or worse)
    I test fitted this EL header and the OEM UL header wit all factory heat shield.
    I still have to fire sleeve the tubes and Hoses. I will also wrap the headers.
    Bottom view:
    Attachment 59637
    tubes under header:
    There is two fingers of clearance between headers and tubes.
    Attachment 59638
    Tubes up the side:
    I have a short piece of vacuum rated in the vertical tubes for flexibility.
    Attachment 59639
    Top View:
    The pump hoses are working out.
    Attachment 59640
  18. #1018
    Worked on mounting dry sump tank tonight.
    These are my scavenge pipes
    Tanks mounted to my rear bumper
    View of rear of car with no bumper cover. Temporary taillights.
  19. #1019
    Visit to local Motors,
    Last week Michael and I got a personal tour of the Local Motors micro factory in Knoxville TN.
    I got to sit in the world's first 3d printed car.
    I also sat in David Riha's FFR Cobra.
    All of his panels are Carbon fiber.
  20. #1020
    Finished my Dry Sump install.
    Finished my Dry Sump install. Just garage tested tonight. Street test tomorrow. Then tracking it this weekend.
    See you Saturday Mitch.
  21. #1021
    Sgt.Gator's Avatar
    Bend, Oregon
    Looks Good! Although I'm still not digging the hard lines...yet.
    For others looking at the pics, the DS pump outlet to the tank is on the side of the pump, not the bottom. The bottom outlet was/is the standard configuration if you buy the kit from Element. I'm sure Bob can attest that putting the -12AN to the side is much easier than connecting it on the bottom.
    And I have two pumps configured with the side outlet if anybody wants one.
    Owner: Colonel Red Racing
    818R ICSCC SPM
  22. #1022
    Hey Gator,
    The hard lines were a PITA to make. But I am very happy with the finish product. Knowing that the hard lines have zero chance of failing from heat, is very satisfying. I will do the hard lines on my second car without hesitation. With all that said, the proof will not be known until a couple of racing seasons.
    The Aviaid side outlet scavenge pump worked out great. A pump with a bottom outlet would have been a pain fitting up the hose.
    Getting the Aviaid dry sump system installed was an engineering exercise (much like the rest of the 818). Having our blown engine on and stand for mock up saved us many hours of frustration.
    Gator, I will need one of your pumps for my second car this winter. See you at SEMA.
    Bob.
  23. #1023
    Bowling Green, KY
    Great news Bob and look forward to seeing you guys. I will not be here all day Saturday (some honey-dos to take care of) but will be at the track all day Sunday.
  24. #1024
    Took the 818 out on some local highways today to test the replacement engine and dry sump system.
    Noticed a couple of things:
    It was a cool day about 60F. coolant temp came up and held 190f very solid. Oil temp came up much slower and only got up to 165F.
    Is that hot enough?
    Oil pressure was in the mid 80psi any thing over 3000 rpms. dropped down into the 30s while Idle speed.
    Idle problem. When leaving off the throttle, the car would stall or almost stall every time. Any suggestions?
    Engine is 04 FXT DBW (TGV deleted) (evap removed) ( PCV removed) stock tune.
  25. #1025
    During our test run tonight, we did a WOT up hill on a highway ramp. Here is a 3 second snap shot. Half way through it we did a 2nd to 3rd shift. I would like for any tuner type guys to make an comments if all is good or you see any problems.
    Also, is there anything else I should be data logging?
  26. #1026
    Great day to go to the track. Video and data logs to follow.
  27. #1027
    Chart of 1st hot lap at NCM today.
    Below is a chart of our first hot lap at NCM Motorsports park today.
    Here are my comments, please add your comments or questions.
    Top purple line is oil temperature, It rises up to 200f, but is doesn't look like its going much higher.
    Next Red line is coolant temperature, It rises up to 188f, but is doesn't look like its going much higher. ambient was 80f.
    The green line is oil pressure. It is hanging around 90PSI. I don't know if I can believe these numbers, seems to high. The press does drop into the 40s at idle.
    The light blue line is intake temperature at the MAF. It is a straight line about 80f as I am snorkeling that from the side vent
    The blue line is speed. About 120 at the start/finish line. 2 minute 30 second lab time. Speed gets as low as 33 in a very tight corner. There was some traffic on this lap.
    The orange line is RPM. High point during the lap is 6800 and low point is 3000.
    The light blue line is boost. I believe the max boost is set to 11.6 PSI 04FXT stock. I am kind of surprised to see my boost hitting peaks of 13 after an up shift. Please comment.
  28. #1028
    Edmonton, Alberta
    Wish I had some feedback to offer bob, I'm sure many are eager to see how the dry sump is working. Glad to see you're back at the track!
    818 SRX - #91
    Arrived 01/02/2014
  29. #1029
    Yeah how's the sump working?
    13psi vs 11.6, that seems like short overboost, I believe it's a common thing but I don't know how often that happens on OEM cars or even if it did happen on the Forester.
  30. #1030
    The dry sump is working great. The oil pressure in much higher than I expected.
    Maybe I need to calibrate my electronics with a mechanical gauge.
    The over-boost is like the waste-gate is slow to open.
    But it's only happening when Michael does a very fast up-shift and slam the pedal back to WOT.
    We were hoping for a full day of testing but had a RUCR event.
    (Rapid Unscheduled Coolant Release)
    Does any one else have comments about the chart above:
    http://thefactoryfiveforum.com/showt...l=1#post255728
  31. #1031
    Senior Member Rob T's Avatar
    Woodruff, SC
    Bob: When my car (Chad's) is all warmed up, I am seeing 90+psi on the oil pressure on the track and 30+ psi at idle. When it is cold, it is 90+ psi all the time. Last time I was out the air temp was 100F. Water temp was 185 - 195 F, Oil temp was190 - 210F with the front coolers taped off, but the back cooler open. AWIC after the intercooler was 110F or ambient +10, which is what I have been seeing. I think we have a similar set-up. Rob T
  32. #1032
    Woodruff, SC
    I am going out again on Friday. I'll take a look at the oil pressure again. It is only supposed to be in the mid 70's, so it will be interesting to see what happens to the water, oil and AWIC temps. If I get ambient plus 10 on the AWIC, I should be making a little more power.
  33. #1033
    Hey Rob,
    I followed Chad progress closely, you got a great car once the oil temp issue was solved.
    For oil cooling I have a MerCruiser liguid/liquid exchanger tied in right before the water pump.
    Your PSI numbers are similar to mine, that alleviates my feelings of distress.
    By the way, I'm running Rotella T6 5W40 Diesel oil.
    I am set up to measure post AWIC temps but I only have 2 free ECU input to data log with, so I chose oil temp and pressure for this test.
    Keep us informed on your numbers. It give us something to shoot for.
  34. #1034
    Woodruff, SC
    Thanks Bob. I am happy to share my numbers and track information with the forum. If there is anything I am missing or anything in particular you or anyone else would like me to watch Friday, just let me know. We are all in this together....
    Rob
  35. #1035
    Rob
    Hey Rob,
    We all like videos, The more on screen info the better.
  36. #1036
    Some pictures from one of our track days this past summer.
    I haven't posted in a while on my own thread. Busy on a few other projects. So here is some pictures from this summer.
  37. #1037
    short story
    Ok so I was at WalMart buying a big bag of dog food and a woman behind me asked if I had a dog. Now why else would I be buying dog chow, RIGHT? So on impulse I said No, I don't have a dog, I'm starting the Purina Diet again, and that I probably shouldn't because I ended up in the hospital last time, but I lost 50 pounds before I woke up in intensive care with IVs in both arms. I told her that it was essentially a perfect diet and all you do is load your pockets with Purina Nuggets and simply eat one or two every time you feel hungry. The food is nutritionally complete so it works well and I was going to try it again. (I have to mention here that practically everyone in line was now enthralled with my story.) Horrified, she asked if I ended up in intensive care because the dog food POISONED me. I said No, I stepped off a curb to sniff a poodle's butt and a car hit me! I thought the guy behind her was going to have a heart attack from laughing so hard.
    Now that you've read it I have to confess - I copied it from someone else... share and make someone else smile today!
    This made me laugh...hope you enjoyed it too. Lol (Have a great day, friends)
  38. #1038
    Woodruff, SC
    You had me going. I used to work for a pet food company, and along with water, dry dog food is nutritionally complete. You could live on it. Our company made it to human food standards, too - because you never know when a kid or something will eat it. Right until the poodle part......
  39. #1039
    Bowling Green, KY
    Got a good laugh from me.
    Saw you and Michael at PRI but was in a meeting and couldn't break away.
    Boy it has been a long time since I have seem the show that busy.
  40. #1040
    Got a good laught from me.
    I am a very visual person. I could just picture this happening at Walmart.
    At PRI, we did a room per day. That was all my feet and ankles could handle.
    We came away with some ideas related to trailers, fuel starvation and front suspension.
    I was surprised there was almost zero EV stuff. I expect EV racing to be 50% of the market in 10-15 years.
    I think you should have a hybrid track day event. Maybe in a few years.
