Results 1 to 19 of 19
Thread: What is it 818
    BN's Avatar
    Sept-lies Qc.Canada +FL. Danvenport
    What is it 818
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Hard to tell 100% for sure but to me those look like the ECU and fuel pump controller relays. I would not delete them.
    iWire's Avatar
    Lake Forest, CA
    The Green plug relay is for the fuel pump, the Black plug relay is for the drive by wire relay, and White/Clear is for the Blower motor. You could delete the White/Clear if you are not using the Subaru HVAC system.
    When we say to our customers "if there is anything you need, please ask," we mean it.
    iWire Subaru Wiring Services
    Over 100 Custom 818 Wiring Harnesses Built
    http://www.iwireservices.com/factory...18-wiring-kits
    [email protected]
    BN's Avatar
    The white/ clear is for the blower motor like for the a/c ? and the white / clear what is it again HVAC systèmes?
    BN's Avatar
    What is drive by wire relay ?
    Syracuse, NY
    Its the electric relay that supplies power to the drive by wire throttle. Newer engines do not have cables that run to the the throttle bodies, small electric motors drive them instead.
    MK3.1 Roadster completed 2011
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    For electronic controlled throttle (electronic setup accellerator pedal <> throttle position, electronic = "drive by wire" and making this one up... old school throttle cable would be "drive by cable" ).That relay supplies 12V to the ECM/throttle control circuit as a safety design to allow completely cutting off power to the throttle body motor so it can't open on a major fault.
    BN's Avatar
    Drive by wire I'm keeping that for sure thanks guys
    BN's Avatar
    Quote Originally Posted by BN View Post
    Did I answer to myself
    iWire's Avatar
    Lake Forest, CA
    You are correct. HVAC is just the heater and AC system.
    [email protected]
    BN's Avatar
    Thank you
    Senior Member AZPete's Avatar
    BN, when you lengthen the DBW wires, do not do what I did! I cut the 6 wires, added similar wires and re-connected all 6 wires. Engine would not run right. Then, I learned about the dotted lines in the wiring diagram. The dotted wire means a shielded wire so be careful with Red, #6 on accelerator position sensor.
    Also, be careful of other dotted lines, like the mass air flow sensor and oxygen sensors.
    BN's Avatar
    Quote Originally Posted by AZPete View Post
    what i did is shild it with alluminum fold than warp it élec tape
    BN's Avatar
    BN's Avatar
    image.jpegimage.jpegimage.jpegand what are those too box
    This thread has many photos of wiring that may help you:
    http://thefactoryfiveforum.com/showt...h-Auto-AC-HVAC
    BN's Avatar
    I would look at the wire colors and then search the PDF schematics for those colors.
    BN's Avatar
    Will do thanks
