Doug @ Forma
We gave one of these a shot on our 818 and eventually gave up on it.
I didn't work directly on this, but I believe this is a shot of the layout they came up with. Good coverage, but I think the dot on the base of the windshield frame is where the motor shaft would need to be to make this happen. If you want more details, I'll ask the guys who worked on it to chime in.
In the end we found an aftermarket wiper and developed a mounting system for it. It's a clean, straightforward solution that mounts to the frame at the base of the windshield and requires no hood trimming to work. We are in the final stages of creating a kit out of it, if you're interested look for info on it in the coming weeks.
Like this??
Mine is near your dot.
