Page 10 of 10 FirstFirst ... 8910
Results 361 to 393 of 393
Thread: nkw8181's 818 build thread
  1. #361
    Sep 2014
    Dallas, TX
    Looks cool with both parts open.
    818S Chassis #288 2.5L 323hp
    joshuajach.com
  2. #362
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Looks very nice Nolan
  3. #363
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    I like it!!
  4. #364
    San Diego Ca 92106
    I like it too. With the black on black I can't exactly make out how the trunk hinge works though, making it hard to steal this idea.
  5. #365
    nkw8181's Avatar
    Dallas, TX
    Look close at the second and third pictures. It pivots at the back after taking out two 5/16 bolts and screws. Eventually it will be a quick disconnect pin. I can take closer pics if you like.
    Nolan
  6. #366
    Senior Member AZPete's Avatar
    An Air Brake - ingenious!
  7. #367
    Freeport, ME
    excellent job on those hinges! I'm surprised how un-obtrusive the black weather stripping is... I've had no luck finding white so it doesn't contrast. Perhaps I'll try the black and see how I feel about it!
    Dan
  8. #368
    nkw8181's Avatar
    Dallas, TX
    yep for a whole millisecond before it flies off lol
    Nolan
  9. #369
    3M Rubberized, eh? Supposed to reduce noise under the panel? For example in the wheel wells, it's supposed to reduce road/tire noise?
    Audi uses a carpet in there and I planned on doing the same but it's heavy and I start to don't like that word on my build...
  10. #370
    San Diego Ca 92106
    Quote Originally Posted by nkw8181 View Post
    Ok I see it, had to turn up the brightest on my iPad.
  11. #371
    Hindsight's Avatar
    Atlanta
    I'm interested to know how 3m rubberized undercoat holds up to the heat in the engine compartment, if that is what you are using. I'd think it would get soft and gummy. I want to use something like that or rhino liner on mine but weight and durability to heat are both concerns for me.
  12. #372
    You could probably apply some heat shield wrap/foil over the 3M stuff, although I'm not sure if it would reduce the good effects of the 3M stuff.
  13. #373
    Feb 2013
    The best I have found is Lizard Skin Ceramic spray insulation. You can brush it on as well and then paint it any color you like. Another benefit is that it is water base.
    All of the bedliners I have experienced did not perform well around high engine heat
  14. #374
    Yeah and that lizard stuff is... say, rather expensive. Couldn't see any temp rating but they do say Class A Fire Rated, which is the lowest flame spread, the one you'd want. It probably handles the heat of the engine, I guess.
  15. #375
    nkw8181's Avatar
    Dallas, TX
    Hmm if I have any issues I'll be sure to pass it on. I am trying a different epoxy to mount my trunk brackets because I guess the one I used didn't like the engine heat anD gave.
    Nolan
  16. #376
    Hindsight's Avatar
    Atlanta
    JB Weld holds up very well to heat. I had a hole poked through a bellhousing once due to a failed clutch. The hole went through to the inside of the trans. A friend told me JB would patch it and hold. I made a $20 bet that it wouldnt. I lost that bet. Held for the next two years i owned it and probably long after. Make sure you prep well.
  17. #377
    Leesburg, VA
    Which epoxy did you use that failed due to heat? I'm about to epoxy a few things in the engine bay.
  18. #378
    nkw8181's Avatar
    Dallas, TX
    Loctite two part 5 min epoxy rated at I think at 3200 psi.
    Nolan
  19. #379
    Leesburg, VA
    Thanks, I picked up some Z-poxy (PT-39) 30 minute epoxy so we'll see if that's any good.
  20. #380
    Plz post results. tnx
  21. #381
    Administrator
    Enterprise Alabama
    SEM 39337 is what I use with excellent results. Knock the gloss off the resin with sandpaper before bonding.
  22. #382
    nkw8181's Avatar
    Dallas, TX
    Thanks I'll let y'all know the reaults.
    Nolan
  23. #383
    nkw8181's Avatar
    Dallas, TX
    I first let me respond on the results. the epoxy ended up breaking. To much vibration. Now to give a long overdue update. I had an engine failure and to make a long story short I am finally up and running again. The car now makes 350 to the wheels which I am more then happy with. I went ahead and ordered the gen 3 carbonfiber and it is a night and day difference. I plan on using the first gen for track days. here are a few pics after down sizing them.
    Nolan
  24. #384
    nkw8181's Avatar
    Dallas, TX
    I don't want to flood this with pics but there are I believe 30 more you can go through if you click on the one above.
    Nolan
  25. #385
    Hey Nolan
    Car looks great.
  26. #386
    nkw8181's Avatar
    Dallas, TX
    Thanks Bob. Your headlight install was a big help
    Nolan
  27. #387
    nkw8181's Avatar
    Dallas, TX
    So I'm ready for my next project. Just thought is post this here. Look at this on eBay http://www.ebay.com/itm/232445793419
    Nolan
  28. #388
    Hindsight's Avatar
    Atlanta
    Wow, good luck with sale. What's next?
  29. #389
    Mar 2015
    Houston, Tx
    Man it would be so awesome if you got somewhere close to asking. It would be a dream if I could get at least 60% of my money back when I move on to my next project..
  30. #390
    Best of luck on the sale.
    What is the next project?
  31. #391
    Administrator
    Enterprise Alabama
    I know, I know!!!! Pick me!!!
  32. #392
    nkw8181's Avatar
    Dallas, TX
    I want to build the new 65 coupe! Yes Wayne you will be involved in the next one
    Figured out eBay a bit better. Added a walk around video and a link to this build thread.
    Look at this on eBay http://www.ebay.com/itm/232455245306
    Nolan
  33. #393
    Hey have you tried selling your 818 to Wayne?
    Can't wait to see your new 65 coming in.
