0
Originally Posted by
melnjoel
I am going to try my hand at adding a photo. Front suspension so far. Does anyone notice anything I have done incorrectly? I would much rather be able to correct it now rather than later!
Hey I think the grease points on the upper control arms go on top not on bottom. You have the lower control arms in the outer holes and with the aluminum lower control arms they need to go in the inside holes. For me I would have also put the nuts on the back side of the spindle bracket but that is your choice. Looks good so far.
