Results 1 to 4 of 4
Thread: group N motor and trans mounts - work great
    Harley818's Avatar
    Vancouver BC
    I just thought I would close the loop on these motor and transmission mounts.
    Some of the early builds used the stock WRX motor and transmission mounts with some excessive movement under high load.
    I saw videos showing up to an inch of front to back movement....!!!1
    I bought the group N trans and motor mounts.
    Fit was great.... dropped right in.
    During recent Dyno testing I was looking closely for movement.
    Very little movement under all loading conditions.
    I'm happy with my choice on these ......
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    Syracuse, NY
    If anyone wants a Group N transmission mount, I have one for sale. PM me if interested.
    MK3.1 Roadster completed 2011
    Senior Member Junty's Avatar
    Dec 2013
    New Zealand
    Try these for even stronger - less movement than GroupN mounts. This type was required for compliance in NZ, incase of rubber failure - the mount must be surrounded by steel. Pleased that this forced me to change from GroupN - as engine & g/box is now very tight.
    I went with these. Very happy.
