Results 1 to 31 of 31
Thread: The Chevy Cobra Went For A Little Drive Today, Go-Kart Style!
    Hey Gang,
    I've made some adjustments and De-Boogered a few things so it was time to take it for a little cruise around the neighborhood.
    The car handles very well in spite of the extra weight of the Iron Headed SBC and very heavy ZF 6-Speed gear box, which tips at nearly 190 pounds with all th fix-ins.
    This weekend I'll be working on mounting the seats thanks to Jeff @ Breeze Automotive and setting up the top of the transmission tunnel so that it will be removable.
    Anyway, I'm finally back to working on the car and man does it feel good to hold and swing my wrenches once more.
    Take Care All & May God Bess You, Your Families & America!
    Nice work Steve. Looking good!
    Amazing how easy it is to climb in and out with no seat. (Or a seat that is a life jacket! Lol).
    I gotta say the most comfortable I ever was in the car was driving it with no seats and sitting on the floor. Very roomy for us tall guys.
    Glad to see you are back at it.
    I'm curious, you mentioned you shortened the wheelbase. How will that affect body fit?
    Hey War Eagle,
    The wheelbase is now 89 3/8" so the top of the rear wheel is directly under the top of the rear wheel arch plus I have good clearance between the tire and rear cockpit aluminum bulkhead so nothing rubs.
    315/35-17's might be tough to clear; however, I'm fitted with 285/40-17's on 10" rears rims that only have a 6.25" back spacing so all looks quite good.
    Thanks For Asking!
    Congrats on the go carting steve!!
    Seasoned Citizen NAZ's Avatar
    Sounds great, congrats.
    Northern VA
    Steve congrats. That sounds great!
    Looks and sounds great Steve!
    Senior Member RickP's Avatar
    Boyertown, PA
    Car runs and sounds great steve. Your really doing a nice job.
    Norton, MA USA earth
    Funny. Even with the SBC and non FFR exhaust, it sill sounds like a Factory Five. Very nice build.
    Congrats! sounds great!
    I appreciate the kind words from everyone, especially since my project has been in an extended holding pattern this year.
    The car does rev very freely, has plenty of power, plus the throttle response of the Edelbrock AVS 800 is excellent; however, I really need to install my Rev-Limiter because the Chevy Cobra hops up to 5,000 RPM's quick. If you Slow The Video Down To 1/2 Or 3/4 Speed, you'll hear that I actually pedal the car a bit when I put the MK-4 into a little wheel spin when showing off at the end of the video clip.
    Again, thanks for the kind words Gentlemen and keep building the best cars on the planet which is anything created by The Great Folks at Factory Five Racing!
    http://www.speedwaymotors.com/MSD-87...ck,107333.html
    Master Builder
    Long Island, NY
    5K RPM is nothing for a SBC Especially a 383 Stroker, should redline about 6500. I had a built 355 that would rev to 9K But not a real street motor.
    Kenny
    Quote Originally Posted by first time builder View Post
    Kenny
    Everything is set up to run between 2,300-6,500 so you "Spot On Called It!"
    I'm really surprised that it will run well between 1,500-2,000 RPM's.
    5th gear at 75 MPH should 2,600 with 6th coming in around 1,750.
    Elk Grove, NorCal
    Thanks for the info about your temporary mufflers ( from your other thread). I really like the way your car sounds. I'm thinking of doing an undercar exhaust on my car. Do you think that size muffler, flowmaster 10, would fit underneath the car under the seats? Or do you think it might hang too low to the ground?
    Quote Originally Posted by Vspeeds View Post
    If you are going with an under exhaust system, then you may want to look at Spintech's Low Profile Cruiser Mufflers.
    http://spintechmufflers.com/sportsma...ofile-muffler/
    They have them in all sorts of configurations, plus you can order custom (You Design It) pieces.
    Elk Grove, NorCal
    I'll check them out. Thanks again
    Lilburn, GA
    Steve, What rear end gears are you running? I have 3.55 and at 75 MPH I'm running 3,000 RPM. TKO 600 5 speed
    The rear is a Dana 44 Style Moser TSD-500 with a 3.73 ring and pinion.
    5th gear is a .75 over drive, with 6th going down to .50 so the car will go way faster than I'm willing to drive it for sure.
    Steve-
    Congratulations and well done! I bet you are very pleased to have reached this point.
    Very happy for you, and I look forward to seeing the rest of your build, if we can get you out of the driver's seat...
    Just went for another test spin, but this time with Mrs. Go-Dad-Go riding shotgun.
    So far we've logged about 20-25 test miles and am happy where we are at this point.
    Attached is what it looks like to ride along from the passenger side of the Chevy Cobra:
    https://youtu.be/yL4UmpII9ek
    Really like the sound -- way cool! I noticed how with the Mrs. aboard you are VERY careful -- SMART! When I have no adult supervision I revert back to when I was 18 when I have a new toy. I'm in the process of wiring mine and hope to have the engine in and fired in a couple weeks. I might just have to take mine for a spin soon.
    Senior Member Lowrod's Avatar
    Nov 2015
    Mount Olive AL.
    Great sound, what color are you paint the body?
    Quote Originally Posted by Lowrod View Post
    The car will be GM Victory Red, which is the same color that Factory Five painted the Edelbrock MK-4 Roadster.
    No hood scoop, no stripes, stainless bumpers, stainless pipes with black roll bars.
    The goal is to be the flavor of CSX-3178, minus the J-Style roll bar.
    https://youtu.be/FJpASOjJWa8
    https://youtu.be/imF-_t6UixU
    Thanks For Asking!
    mcwho's Avatar
    DeBary - Florida
    Steve,
    That will be a great color. I have been watching your progress even though I haven't posted on much lately cause of a few projects that are getting in the way. I found another home to buy and I have volunteered to help a friend of mine in Europe puchace an indian motorcycle and sidecar and store it for a few months.
    I love the thought that you went with a Chevy engine, does that make your car a "Chobra" (smile). I think the reason Chrysler and chevy didn't get to use their engines in the cobra when Carroll was sopping is cause they put the distributors in the wrong place (smail again).
    Hope you have seen my recent paint pics, 12 coats, ruby Red, a Ford color.
    Also glad to see that you are NOT underwater !!!
    Baghdad Bob
    Baghdad Bob
    Senior Member smithbks's Avatar
    Mar 2014
    Atlee, VA
    Great job Steve! It has been cool to see your build progress. Keep having fun with it. Can't wait for you to take me for a spin when I drop by next month.
    Mk4 #8340, 351w/427, 3-link, Wilwood 4 piston rear brakes, 3.27 gear, TKO600, delivered June 18th, 2014
    Fairfax Station VA
    Congrats Steve. It's a ton of fun go karting, isn't it?
    MK IV Roadster #8631
    On a roll Al_C's Avatar
    Wheaton, IL
    Looks and sounds great!
    Thanks, Gentlemen!
    Next phase will be seats, safety harnesses and cockpit carpeting.
    Apr 2015
    Irving, TX
    Congrats, its all down hill once you get it running!
    Southern WV
    Are you going to do any kind of cold air intake?
    I started to do mine without a scoop but it was so hot that I decided to add the scoop.
    It made it a lot cooler but now I'm looking at adding a turkey pan to make sure I have cold intake air at low speeds or when stopped.
    Love the build pics great job
    Rick
    Quote Originally Posted by Itchief View Post
    Rick
    I'm not sure at this point what I will do since I don't have the body on the car.
    With that being said, I don't know if I'll have under hood heat issues or not.
    Also, since the engine sits a good bit further forward, my hope is that that I'll have more air circulation under the hood than most folks.
    Finally, I hope the Turkey Pan Solution works out for you.
