I pulled into a Service station to fill the tank. It took 14.5 gallons, but I thought I had at least another gallon or so left in the tank. Could the current tank be 18 gal capacity. If not, yikes, I made it just in time.
Road Legal August 31, 2017
14.6 plus a little on the fuel neck
You might want to adopt the 1/4 tank is empty. At least you didn't have to push it.
Texas Cobra Club-Austin
July 2009 FFCars Picture of the Month
FFR3542K, 347 C.I., EFI, T-5, 3-Link, Miata Front Sway Bar, Red with White Stripes
Not sure what the complete kit comes with but most of the mustang tanks are 15.4 Gallons.
Jay, I love driving in downtown Lake Geneva! All those cars diagonally parked with the alarms on... do I need to say more?!
I've put 14.95 in my tank a couple of times and the gauge showed about 1/8 tank before filling.
King
Wow, talk about playing it close.
Saturday morning my gas gauge was midway between the 1/2 and the 1/4 mark and it took 10.2 gallons to fill. That's about as low as I let it go before looking for a gas station. If it get's to the 1/4 mark I figure I have about 3 gallons left and I better be sitting at the pump.
FFR 4440 - V8, Manual Trans, Htr, WSW, IRS. I wouldn't change a thing.
Jay - Just to make sure your build it period-correct, I'm going to get you a stick like they used on the original cars to check the fuel level.... you may have trouble getting it down that filler neck, though. LOL ;-)
Later,
Mk3.1 #7074
When I build using the Speedhut gauges I do the manual calibration and set the "empty" point with about 2 gallons in the tank then fill it and set "full".
