Results 1 to 15 of 15
Thread: Uncured gel coat?
    Jacob's Avatar
    Rogers, AR
    Uncured gel coat?
    Not sure exactly how to handle this but today I was probing around the seams as I was getting ready to start sanding the gel coat...and found some areas where the outside of the body form were stiff and brittle but as I probed underneath the hard outer surface there was quite a bit of uncured gelcoat. So I am assuming that I need to remove the outer surface until I stop finding uncured gel coat and then rebuild that area with body filler? Is this the correct way to proceed? Appreciate any help!
    MK IV complete Kit - 1st time builder started Sept 2016
    Levy 306
    T5
    2015 Mustang IRS
    Power steering - Levy setup, Breeze roll bars, Thompson trunk box
    fuel injection, powder coating, sway bars, heater, wipers, 17 in wheels
    Jacob, when did you receive your kit? I've sent an email to FFR, and will report back when they respond.
    Hopefully they will chime in; would also love to hear what some of the vendor painters have to say (Setting up the BAT signal as we speak)
    Raleigh NC, OIB NC
    Why not see if FFR will take it back & give you a good one?
    Kevin
    MKIV #8234
    Jacob's Avatar
    Rogers, AR
    I got the complete kit August 2016. I haven't called FFR but guess I should. I was assuming this is a common issue? It looks to me that to make it work you'd have to grind off the outer shell until you stopped getting "goo"? If you've ever had one of those chocolate covered ice cream bars, it's hard on the outside but soft underneath.
    Levy 306
    T5
    2015 Mustang IRS
    Banned
    Aug 2011
    Is it uncured gelcoat or colored clay? All of that has to be removed either way.
    Jacob's Avatar
    Rogers, AR
    Must be gelcoat, couldn't get off my fingers with paint thinner or anything else?
    Levy 306
    T5
    2015 Mustang IRS
    Acetone will get it off of your fingers.
    Nail polish remover will work too, but it will take longer.
    Also, the uncured Gel-Coat was obviously not properly catalyzed.
    I wonder if they where using a gun that catalyzes at the tip, a pressure pot unit or my favorite, Ye-Old One Quart Dump Gun.
    http://www.uscomposites.com/equipment.html
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    I found a cavity of that in my Mk3.1 back when I did the bodywork - had to do quite a bit of grinding to get it out. It was located along the mold parting line directly above the front driver's side wheel.
    Here's a pic of it during and after the operation to remove. Once done, I repaired the area with filler and it has held up fine.
    Overhead and profile of the cleaned area with a straight edge over top.....
    Finished....
    Later,
    Mk3.1 #7074
    I'd be more worried about the uncured gelcoat you haven't found. What are the odds that it is only in that exact spot? If not cured by now it will never cure and rear its head later. I would go for a new body. If replacing the body is not an option, I'd fill low areas with 3M HSRF and finish with normal body filler products. If super deep, I'd fill with 1/2" chopped fibers and vinylester resin, then bodywork as normal.
    Banned
    Loveland, CO
    The problem looks minor compared to what I've had to repair. Remove all of the uncured material and repair with chopped fiber and resin as already recommended. I find that cutting fiberglass mat into narrow strips with scissors, then cutting it into short lengths makes nice chopped fiber. I bought a big bag of 1/4" chopped fiber that did not work well at all - it was extremely difficult to get wetted.
    Get a gallon of acetone for clean-up when working with fiberglass resin. You'll also need a bunch of nitrile gloves. I like tiger-grip gloves. None of them hold up to much acetone exposure.
    Quote Originally Posted by Jacob View Post
    There have been numerous issues with the parting lines being contaminated over the years, resulting in grinding, filling, etc. But the later versions (e.g. your Mk4) not so much. What you're dealing with is definitely not common. I'd start by calling FFR. Probably can be fixed by maybe there are other options.
    Jacob's Avatar
    Rogers, AR
    thanks all!
    Levy 306
    T5
    2015 Mustang IRS
    I've encountered it a few times but must say that the globs were not that big. I dug, ground and cleaned them out then filled with HSRF and Rage. As much as 6+ years later on some of them and thus far none have reared their ugly heads.
    bobl's Avatar
    Spicewood, Texas
    I had some pretty big globs in my MK IV also. It seems to be pretty normal, some more than others. I just dug it out and ground until I had a good clean surface then filled it with HSRF. I never found one that went so deep that it needed actual fiberglass repair.
    Jacob's Avatar
    Rogers, AR
    I called FFR today and in summary they recommended the fix you mention, grind it out until no more goo, clean with acetone, fill with HSRF and finish off with body filler. In essence not a big deal, regrettable and unfortunate but fixable. Not saying I'm a body shop expert but I think I can handle it. I'll post results in my build log. thanks all
    Levy 306
    T5
    2015 Mustang IRS
