![BluePrint Engines](https://www.factoryfive.com/wp-content/uploads/2015/12/BluePrint_Engines_Factory_Five_banner_ad_revised.gif)
Brakes that come with complete kit - What year of stang will they fit on?
Hi Guys,
I'm trying to sell the brakes that came with my complete kit. My kit was delivered last Labor day. I believe they are PBR brakes? I have a guy that is interested. He wants to know if they'll fit on a 94-95 mustang? Will they fit a 90 mustang?
Thanks!
Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022, First start 6/13/2024
Serial #9158
Not a waxer
The do not directly fit either however the '99 and later PBR dual piston calipers can be used on the earlier SN95 spindles by doing some grinding of the spindles at the caliper mounting ears to provide clearance. Note that to maintain balance the master cylinder will need to be changed as well because of the differing piston area between the single and dual calipers. It's a fairly common swap. Only way to use them on a '90 Fox body is by changing to SN95 spindles.
Thanks Jeff! Great info! If I ever meet you in person, remind me I owe you few beers.
Serial #9158
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
