Been a few months since I posted so I thought I would give a quick update.
Engine was finished up in November and got it installed without too much trouble. Clutch and transmission went in smoothly as well. Getting the rear axles in was a pain since the only way I could figure out how to do it was to completely disassemble everything first.
https://photos.app.goo.gl/lIzzGAbJlAO9gJoh1
Gas tank also went in. I did use some fuel cell foam and a hydramat to hopefully prevent any starvation issues.
https://photos.app.goo.gl/2PfhklPg6nueU6Aw1
I also installed the brake and clutch lines. I am not real happy with the brake line routing and I am almost sure I will have some leaks given it was my first attempt at flaring. I will consider this my practice run and once I prime the lines, see what needs to be replaced and if I can route it any better.
https://photos.app.goo.gl/yXXmmAveE9IpBPTJ3
Also got the radiator and AWIC installed. I am going with a hybrid BOV/BPV. The biggest pain for the AWIC was getting the re-circulation line connected. If the line coming off the BPV is not angled correctly, getting it to line up with the re-circulation line at the turbo inlet is a pain. Have not mounted the pump or run the lines from the intercooler yet.
https://photos.app.goo.gl/MluxcUmmptZ8df5r1
Finally decided on the brakes and just finished up installing those last week.
https://photos.app.goo.gl/gjn2qHb0Nkxj9Poq1
Up next is the wiring harness, which I plan to try and do myself.
