Thanks Thanks:  61
Likes Likes:  403
Page 12 of 27 FirstFirst ... 2101112131422 ... LastLast
Results 441 to 480 of 1072
Thread: John's EZ36R H6 818R Build
  1. #441
    Jan 2018
    North Bay, California
    Righteous build! Love it! Makes me wanna do one next, or just for a track car!
  2. #442
    Well, that answers that!
  3. #443
    Syracuse, NY
    Headers Fixed!
    Finally got some time to weld up the cracks in my header collectors. Turns out its really hard to weld down inside a small tube
    Here is a shot looking down into the collector to see the weld I put in.
    Here is a pic from the outside showing the weld penetration. Man that ceramic coating is tough, didn't blister or peel! I did end up grinding it off to weld the crack from the outside as well.
    MK3.1 Roadster completed 2011
  4. #444
    Mar 2014
    Oakley, CA
    Did you MIG or TIG that? I'm guessing MIG?
    The weld bead looks very nice, but I don't think you got good penetration. In this case it's kind of a blessing, since if you got full penetration, you would have pulled in the ceramic coating from the outside into the bead, which would have contaminated it and weakened it.
    Here's a link to a professional welder who's been publishing welding advice on the web for years. The bottom of the page gives some pointers on penetration.
    http://www.weldingtipsandtricks.com/...ding-tips.html
  5. #445
    Syracuse, NY
    Quote Originally Posted by Zach34 View Post
    MIG, I could not fit the TIG torch down into the hole!
  6. #446
    Syracuse, NY
    Some video of the finished product in action!
    Well the first time I had the car on track at Watkins Glen I did not have video for you guys. But as promised I have video for my second track outing. This was my first time at the New York Safety Track so you'll have to excuse my terrible lines and timid driving
    The track is primarily a motorcycle track so its tight and twisty. I like that it is very technical with 18 turns, 16 of which are BLIND! I will definitely be returning.
  7. Likes biknman liked this post
  8. #447
    Syracuse, NY
    Some final issues to work out
    There are a few things that still need to be addressed with my car before I can call it done.
    1. I have not gotten the Variable Valve Timing working yet so I'm losing some mid to top end power
    2. The aero needs to be sorted
    3. The suspension settings need to be sorted
    4. The trans mount needs to be redesigned
    During the second session at NYST I broke the rear transmission mount. The polyurethane separated from the top plate and it made a clunking noise every time the engine/trans shifted weight front to back. This ended my 3rd session early. But the track marshal and I came up with a nice temporary fix. I took a ratchet strap and looped it around the tail of the transmission and the frame section below the mount and tightened it down. It held the transmission snug against the mount for the rest of the day! Now I need to think of a more permanent solution.
  9. #448
    San Diego Ca 92106
    That engine sings beautifully
  10. #449
    Leesburg, VA
    Great video, thanks for sharing!
  11. #450
    Bowling Green, KY
    Car sounds great, enjoy the sorting and chassis tuning. I found the car responds really well to chassis changes.
  12. #451
    Syracuse, NY
    It was real hot, around 95F with a feels like temp of 102F. I looked at the logs and max temps were great except for the intake air temp. I need to make a duct to grab air from one of the side scoops as it is just sucking engine bay air at the moment.
    • Coolant: 192F
    • Oil: 215F
    • Trans: 205F
    • Air: 104F
    Really pleased with all the plumbing and cooling stuff I put in.
  13. #452
    Bowling Green, KY
    I am using the right side scoop to draw intake air and is working well for my car.
  14. #453
    Nepa
    why do you think the trans mount separated? did you use there primer? was there a profile on the metal to help? car looks and sounds great!
  15. #454
    Atlanta, GA
    What engine mounts are you running? It's possible that since you made a stiffer trans mount, if the engine mounts are stock or not stiff enough then more load will be carried by the trans mount (until it breaks of course). I don't know if that's the case for you, but if it is maybe look into matching the stiffness and range of motion for both the engine and trans mount so the load is balanced.
    Car looks great on track!
  16. #455
    Syracuse, NY
    Here is the separated trans mount.
    Quote Originally Posted by Samiam1017 View Post
    No primer (instructions didn't call for it) and not really much profile for it to bite into, just media blasted. I think its not really meant to be used in tension.
    Quote Originally Posted by lsfourwheeler View Post
    Using Subaru STI Group N motor mounts with custom top plates. They're plenty stiff but provide no real forward / back support. That is supposed to be handled by either the front dog bone, the trans mount, or both.
    And here is my temporary fix as I need to be ready for the next track event at Watkins Glen in 2 weeks. Who knows, if it holds up well it could be my permanent fix
  17. #456
    one of the engine mounts I made did the same thing when I tightened it to the frame, but the top and bottom plates weren't exactly parallel, so torqueing the nut down pulled the lower plate away. I'm pondering that problem, too, and wondering if the others are problems waiting to happen. I kinda like your fix for the trans mount, though. Can still squish together, but not stretch apart. Actually, I kinda REALLY like it.
  18. #457
    what about screwing a whole bunch of hex head screws into the top plate before pouring your urathane to really give it something to grab on to.
  19. #458
    Sgt.Gator's Avatar
    Bend, Oregon
    Are you logging oil pressure? The oil control problem in the H6 is the main thing stopping me from jumping in with one.
    Owner: Colonel Red Racing
    818R ICSCC SPM
  20. #459
    Nepa
    i like the new solution for the trans mount. how about welding it solid and using a small piece of rubber under the mount for a little compliance? i have to run a thinner poured mount like yourself and have chosen the later. hopefully its not too stiff.
  21. #460
    Syracuse, NY
    That might work but its still a lot to ask putting an adhesive in tension and shock loading. I think my quick fix may turn out to be the easiest and best. I'll know for sure in two weeks when I track it again.
    If I was starting from scratch with the knowledge I have now I would most likely do that.
  22. #461
    Syracuse, NY
    No oil pressure issues pulling up to 1.6G is the sweepers! I am logging pressure both before and after the accusump so I know for sure if / when the oil moves away from the pickup. But I only have two full track days so far. I'll report back after two more days at Watkins Glen. That is a very fast, high G track.
    You know you want to join the H6 club
  23. #462
    Syracuse, NY
    Oil Pressures During Track Session
    Here is a scatter plot of the oil pressures during a 15 min track session with lateral G's in the 1.5 range. This plot shows the pre oil pressure (that's from the pump to the accusump) on the X axis and the post oil pressure (that's after the accusump to the motor galleys) on the Y axis. The color denotes RPM.
    When hot, the pressures range from about 25 psi around idle to a max of 88 psi. That must be the internal pressure relief as you can see an abrupt cut off in pressure rise on the right side.
    Everything looks pretty normal.
  24. #463
    Sgt.Gator's Avatar
    Bend, Oregon
    Interesting graph. I'm probably not reading it correctly because it looks to me like you have a lot of high rpm (Orange and Red dots) between 24 psi and 45 psi. I wouldn't think you should ever have a high rpm colored dot at such low pressures. And how do you tell a Pre Oil from a Post oil dot?
    Can you do a straight oil pressure vs G graph all at a single rpm, like 5,500? Or eliminate the G and do a oil pressure vs time with a rpm overlaid? Like this:
    818R ICSCC SPM
  25. #464
    Mar 2014
    Oakley, CA
    Also interested in what Gator pointed out.
    I'm unfamiliar with accusumps, but my eyebrow raised at what appears to be somewhere around a 33% oil pressure drop at the higher pressure ranges across the accusump. Is this a known tradeoff with those things?
  26. #465
    Syracuse, NY
    You can't tell a pre dot from a post dot without hovering over it with the mouse pointer. I just use the scatter plot to get an overall picture of the entire log file all at once. This way I don't have to scan through a huge log if I'm just looking for say a large dip in oil pressure.
    Here is a line graph like what you asked for, but as I mentioned its just a small time frame in the log. It does point out some things.
    1. You can see the red pre pressure trace bouncing off the pressure relief spring (that's why its top is flat at about 88 psi).
    2. The green post pressure trace is more evened out, that's the effect the accusump has evening out highs and lows.
    3. The green post trace also exhibits a pressure drop due to the cooler and additional plumbing.
    The accusump combined with the cooler and extra plumbing cause a pressure drop, this happens in all systems, its not unique to the accusump. Most people only log one oil pressure so they don't see the pressure drop in their system.
  27. #466
    Sgt.Gator's Avatar
    Bend, Oregon
    The next time you go out if you can log one flying lap then you can compare your oil pressures and RPM to particular corners and see if any of them are causing an issue.
    818R ICSCC SPM
  28. #467
    Syracuse, NY
    Yeah, I'm trying to figure out how to get my ECU data and my telemetry data into one system so I can do easy direct comparisons. Have not found any way as yet, but I'm still trying.
  29. #468
    Syracuse, NY
    One Lap of the Glen in the 818R
    Well, still working out the kinks. Day one I broke the shifter cable that controls forward and backward motion. We cobbled it back together so we could salvage day two. Then on day two the oil catch can filled up and spewed oil everywhere, and I do mean everywhere! That ended day two early.
    But I do have a lap from day 2 before the the oil bath. Enjoy
  30. Likes Zach34 liked this post
  31. #469
    Sgt.Gator's Avatar
    Bend, Oregon
    "Then on day two the oil catch can filled up and spewed oil everywhere, and I do mean everywhere! That ended day two early."
    Classic Subaru track day!
    818R ICSCC SPM
  32. #470
    Apr 2018
    "But I do have a lap from day 2 before the the oil bath. "
    Nice lap...aren't oil baths only good for the Tin Man?
    "trying to figure out how to get my ECU data and my telemetry data into one system so I can do easy direct comparisons" --- can the 2 be run off a master clock, if so then post processing based upon time stamps would be possible.
  33. #471
    Syracuse, NY
    Quote Originally Posted by DetactGarageMech View Post
    They can't be run off the same clock. The GPS lap timer get time from GPS satellites and the ECU only records seconds since data logging began, its internal clock is only used to time stamp the log files it creates so inside the files there is no full time field.
  34. #472
    Loveland Ohio
    Just finished reading your build from first post to last, thanks for taking us along! Very nice work both on the car and documenting the build and sharing with everybody. Two thumbs up, Makes me want to build one! Thanks again for a very enjoyable couple hrs
  35. #473
    Syracuse, NY
    Shorter 5th gear needed in the 5MT!
    In the short time I've been running my 818R on the track, I have noticed that the step from 4th to 5th gear is too large. The car falls on its face when going down the long straights after shifting into 5th.
    The 06 WRX 5MT (and all USDM WRX 5MT's I think) have a 0.738 ratio 5th gear set. This is great for highway cruising and gas mileage but not so good for road racing. So I started looking for a shorter 5th gear set. My research uncovered that the 08-09 Outback with an EJ253 had a 5th gear ratio of 0.825. This close ratio 5th should be much better for the car.
    Having rebuilt the 5MT once before I think I can replace the current 5th gear set with the transmission still in the car, only removing the center differential section. That's the section right behind the FFR block off plate.
    I'll post pics when I do the conversion and let you know how it goes.
    If anyone else is interested, the Subaru part number for the 5th gear set is 32315AA390. It is a special order part with limited quantities remaining so get them while they last!
  36. #474
    Williamsburg VA
    Hey yes you can do the converion in the car. You will need a thin wall socket to get one of the nuts off. Plus the upper gear is pressed on so I just cut a slot in the top gear and cracked the gear to get it off. The nut will push it back in place. I tried the .871 5th gear and ran into the rpm limiter at around 140 mph with my 4.11 final drive trans. I installed the .78 5th gear in mine to stay off the limiter and still push me over 150. Depending on tire size and if you have the 3.90 final ratio you should be happy with your choice. The rpms don’t drop much when you shift into 5th now so I find myself double checking that I shifted.
  37. #475
    Syracuse, NY
    Quote Originally Posted by taco20 View Post
    With the top gear, do you think it will be possible to get a gear puller in there to pull it off?
    I have the tallest final drive ratio, 3.70 so I think the shorter 0.825 will work great for me. Here is a chart showing the gear spreads.
  38. #476
    Williamsburg VA
    It is actually the lower gear that is pressed on. As you can see from my pics there is no real room to put a gear puller behind the gear. Plus with the shaft in the way it makes things even more difficult. Cutting the gear sucks but you have decided not to use the gear set anyway. With your short tire and tall final drive I think you will like the .825 ratio just fine.
  39. #477
    Syracuse, NY
    What tool did you use to cut the gear and in what location. It looks very close to the case so cutting in the teeth gullet seems risky. Also, how did you lock the gear set up to apply the torque to the nuts?
  40. #478
    Williamsburg VA
    I just used a cutting wheel at an angle. I nicked the plate holding it in but not going to hurt anything.
    Since it is still hooked to the motor just shove one of the shift levers in and put it in gear. Then use an impac wrench to take the nuts off. The aren't super tight. The big nut needs to be a thin wall sock other wise you have to grind down the tip of the socket until it fits. I believe it is a 35mm. I bought a cheap one form Autozone that worked fine.
  41. #479
    Syracuse, NY
    @taco20
    How did you get the big 50mm nut off? I have a 50MM socket but its no where near deep enough!
  42. #480
    Williamsburg VA
    I bought a 50mm socket off the tool truck in 3/4 drive that just fits. Might find a 2" socket that is deep enough to do the job?
    I could always mail you mine but shipping might cost more then a socket being shipped back and forth.
