Page 12 of 26 FirstFirst ... 2101112131422 ... LastLast
Results 441 to 480 of 1007
Thread: 818 Project Updates From Dave
  1. #441
    Senior Member PhyrraM's Avatar
    Quote Originally Posted by Niburu View Post
    Do you think the oil cooler will be moved up there as well?
    The oil cooler, on cars that have them, is water cooled. It uses a coolant loop off the water pump.
  2. #442
    Christiansburg, VA
    Thanks for the Monday morning laugh. I do agree though, the GRM pic looked goofy, I just didn't open my mouth and keep faith that the end product would have been far different.
  3. #443
    i wonder if he means an aftermarket oil cooler, either they mount behind the radiator or on the top of the motor where the top mount intercooler goes... of course if you want this it is because you have a front mount intercooler
    http://www.blinemotorsports.com/oilcool.html
    i imagine unless you are putting down a stupid amount of power you wouldnt need this... a larger oil pan would do better
  4. #444
    Z Nut
    Vacaville, CA
    Quote Originally Posted by PhyrraM View Post
    Though I've seen that, I've seen them be freestanding as well. I've even owned a couple of engines that might be one of the first japanese motors with an OEM oil cooler, the L28ET from the 81-83 280ZX turbo. It was a fully fledged tank and end cap design, not a cheap bent line with fins attached like what you see on many cheap ebay coolers too!
    Point being, many oil coolers ARE standalone systems that aren't attached to the coolant system. That said though, they don't require huge amounts of air flow.
  5. #445
    I have heard of nothing but benefits from shunting cooling to the oil system. A thermostatically controlled oil-air cooler set to pull the oil temps down to <200°F would help a great deal, especially in a performance oriented vehicle that's destined to see WOT on every on-ramp it sees.
  6. #446
    Senior Member Steve91T's Avatar
    Huntersville, NC
    Don't forget, this can also raise the water temps. It goes both ways. I personally would rather have an inexpensive, simple, air to air oil cooler.
    Weekends/track days
    1997 Camaro SS 380 rwhp/380 rwtq
    LT1 Stroked to 396. C5 brakes, suspension work, racing seats, roll bar
    Daily driver
    1999 Ford F250 Powerstroke 300 rwhp/600 rwtq
    Custom intake, 4" exhaust, 80 hp DP Tuner PCM tuning 20 MPG highway!
  7. #447
    I was only refering to the stock system.
    Of course, if you choose aftermarket, the sky is the limit.
  8. #448
    Senior Member Doc_FFR's Avatar
    The old spy shots look like the Honda S2000 to me. The production values looked a little "symple" if you know what I mean (No offense). Glad to see things like complex curves and lasers and whatnot. Keep up the good work.
    I'm waiting to see how the prototype turns out.
  9. #449
    Senior Member kach22i's Avatar
    Michigan
    Quote Originally Posted by Doc_FFR View Post
    I can definitely see that comparison too, it's a good one. The hood is lower and hind quarters of the S2000 is unadorned, but the mouth is there.
    http://www.carpictures.com/Honda/S20...04EHI273826955
    George; Architect, Artist and Designer of Objects
    1977 Porsche 911 Targa, 2.7L CIS Silver/Black, owned since 2003
    1998 Chevy S-10 Pick-Up Truck 4x4 4.3L V6 Black with front and rear spoilers
    1989 Scat II HP hovercraft with Cuyuna two stroke ULII-02, 35 hp with experimental skirt and sound control
  10. #450
    Kansas City-ish Kansas or, Oklahoma City depending, sheesh...
    Talking about oil coolers that are incorporated into the water cooling system... After talking to a Ford Engineer about their oil cooler on the first 4.6 engines, I learned that the oil temps were controlled both ways. On cold engine startup the water temps go up first. If the oil is circulated through a water heat exchange (the oil cooler) while the water is warming, then the oil is actually brought up to temp sooner. This allows the oil to work at design temp sooner. Then as the oil temp rises the water heat exchange then become an oil cooler. Just a bit of info...
  11. #451
    Sep 2011
    Columbus, OH
    Quote Originally Posted by Nelff View Post
    Yup. A lot of people who have both an aftermarket coolant temp gauge and oil temp gauge have commented on that behavior, and not just in Ford's.
  12. #452
    Christiansburg, VA
    You also can get oil that doesn't heat up fully during short drives to release condensate, allowing it to build. This is also a bad thing for large air cooled systems.
  13. #453
    Aliso Viejo, CA
    Quote Originally Posted by Dave Smith View Post
    I have 20 PM's that I havent had time to get to! BUT I just couldnt take the criticism and the guys here wanted to wait until the 4 unveil and gloat and say "told you so" but I guess I'm a fragile guy... MR2! Seriously, thanks for the great comments all thru this process which continues with such professionalism and careful consideration. Jim and Jesper have been outstanding and patient. This 818 project is very exciting to me as I am trying to ensure, as I said previously, that our "reach exceeds our grasp". There is so much more to show! Dave
    We believe in you man. You've already brought us some great cars and we can't wait for another. Proof this is how your "818 Project updates from DAVE" has turned into such an opinionated chat session! It's hard to even find your updates! Keep up the great work man, the car is looking great.
  14. #454
    Z Nut
    Vacaville, CA
    Kind of off topic, but if you're really concerned about oil warm up temps, you can get a heating pad designed for people in the frozen north to not require block heaters. Set it on a timer for 15-30 minutes before you leave in the morning and you'll have an engine (and transmission if you get a heater big enough for that too) that's nearly at temp right at the start. Makes for one happy engine.
  15. #455
    OK Dave, I am just about ready to order a kit right now. I don't want/need to wait for your final body design array, I like what I have seen so far and Factory Five has long since earned my trust. Let's forget about the body designs for the moment and concentrate on finishing the chassis design and putting together a useable build parts list and build instructions so that those of us who feel as I do can start now. Later you can show us the body alternatives available. I am assuming that the chassis pick-up points for the body will work for each of the design alternatives, right? If yes, what are we waiting for? If not, I womder why not? I want to source my subi donor now, accumulate parts and start wrenching. I want my 818 however it is pronounced!
  16. #456
    Senior Member Oppenheimer's Avatar
    Milford, CT
    Quote Originally Posted by David Budd View Post
    Well I'm sure that is their hope/plan, but the body designs aren't even close to decided yet, so how could they be sure the same chassis pick-up points will work for all the bodies?
    I would think though it would be the same basic chassis, then any chassis pick-up points that are dramatically different from one body to the next would be accomodated by bolt-on or weld-on sub-frames.
    But I think the biggest reason they can't get you a parts list yet is they won't know how much they can reuse off the donor until they get farther along with the body. Are there hinges & latches they can reuse? Lamps, fixtures, seats, dash pieces, etc? I don't think they can figure all that out until they have the bodies figured out.
    I think the basics of your idea is a good one, get the parts list sorted as soon as possible, even before the car is ready for sale, so people that want to can get a jump on their builds. The sooner these cars hit the streets the sooner the floodgates will open on people outside this community looking to buy.
    I just think that day is a lot later than sooner (based on how much left to do to get there).
  17. #457
    Well I have to say from the page before and this thread http://thefactoryfiveforum.com/showt...t-Model-1-of-4
    I am really excited! I can't express in words.......so I will express my excitement through graphics.
  18. #458
    Largo, Florida
    818 kg
    Dave,
    I have a question about the target weight. I would think that not all trims of the 818 would weigh the exact same. I would think that the track version would weigh a but less than the road going version, especially if it is missing a roof, doors and a windshield. I would guess that the road and high mileage versions would also have more interior trim and possibly a radio, heat, maybe even A/C? If so equipped, the WRX turbo and intercooler system would also add some weight. Granted, the track version might have a cage that would add back some weight. This begs the question, does the 818kg target apply to all trims, or just one that is "bare bones?" Could we possibly see a road going version that weighs 818 kg, but a track version that weighs even less?
  19. #459
    Quote Originally Posted by Gollum View Post
    https://www.subarugenuineparts.com/p...products_id=65
    30$ super easy to install and works like a charm
  20. #460
    President, Factory Five Racing Dave Smith's Avatar
    Barrington, RI
    Quote Originally Posted by BipDBo View Post
    Dave,
    Good question. Obviously the trim will affetc the car pretty substantially. I recall Jesper's (Dir of Engineering) Mk3 weighed about 150 lbs more than "average" Mk3 due to add ons like a huge stereo system, abs brakes, soft top and other stuff. With respect to the 818 we see weights between 1600 (Jim major eye twitch as he races right now at watkins glen and doesnt know why), and maybe close to 2,000 lbs hard top, major changes in running gear, etc. BUT the core 818 roadster will not fail the weight target and we have some cool tricks up our sleeve on the composites side to keep it honest and within the goal.
    Dave Smith, FFR 001
    President
    Factory Five Racing
  21. #461
    Largo, Florida
    Mmmm
    My mouth is watering.
  22. #462
    Sep 2011
    Columbus, OH
    If a stripped down 818 (no top, no radio, minimalist interior) can approach 1600lbs, I'll... I don't know... probably lose the top of my head as my grin reaches all the way around my skull.
    *plays with numbers*
    Oh wow... 500 hp/ton with a 400 crank hp motor.
    *collapses into a grinning, drooling pile of flesh*
  23. #463
    i am under the impression with some well spent money you could shave even wieght, a lightwieght battery and very light rims would be a nice start
  24. #464
    Senior Member ScottKoschwitz's Avatar
    Milford, CT
    The performance potential of something that light sounds great. Frankly, many who have experience with only modern cars probably have never driven something that light, short of a race car. Hell, my '09 VW GTI is about 3,100 pounds (I still don't understand why it is that heavy). With 200 hp, it's almost too fast for the road, meaning when you put your foot into it, you're at 80 mph before you know it and have to reign it in before you get into too much trouble.
  25. #465
    Sep 2011
    Columbus, OH
    Quote Originally Posted by Ks2 View Post
    Even better spent money:
    This:
    Is started by this:
    And it costs less than $40, and I can palm it in one hand.
  26. #466
    i didnt say it had to be alot.... more then one drag car nearby me is lightwieght thanks to a hole saw...
  27. #467
    Michigan
    Have you guys seen the spy shots the Wookie (David) posted today?
    http://thefactoryfiveforum.com/showt...-WITH-A-CAMERA!
  28. #468
    Sep 2011
    Columbus, OH
    Quote Originally Posted by kach22i View Post
    I like the flares on the rear wheel arches. They offer perfect "Cut here" lines for pocket flares to cover wide, low offset wheels.
  29. #469
    Sep 2011
    Columbus, OH
    Something has occurred to me. I know they have 4 or 5 designs to reveal at SEMA. But they also have a full-scale model they are building. Would they have gone through all that effort if it was only a 1 in 4 chance they'd use the body?
  30. #470
    Senior Member thebeerbaron's Avatar
    NYC
    Quote Originally Posted by Draco-REX View Post
    I think yes. I believe the scale was a function of the way it was built/carved/designed and possibly the materials.
  31. #471
    Senior Member Silvertop's Avatar
    Forest Lake MN
    Quote Originally Posted by thebeerbaron View Post
    I think you are right about that. They WOULD build it full scale even if there was only a 1-in-4 chance of production. But I think the odds are better than 1-in-4. It is my personal belief that at least 3 of the 4 cars currently being modeled are destined for production, unless they are received poorly at the reveal. The big question is which one will they build FIRST?
    Incidentally, the conspiracy theorist in me believes that there are really 5 models currently being made, with the X-818-R being #5. Of course, my believing it doesn't make it so..........
  32. #472
    I believe another reason why they created a full size model was to study what the proportions look like when reduced to 1/4 scale. By studying how it translates from full size to 1/4 scale, it will help them learn what to expect when they translate the 1/4 scale to full size. For example, a side air intake might look good in quarter scale, but look oversized when blown up. By taking known measurments of the full size model and reducing them, and then comparing how they look against the other 1/4 scale models, they will be better able to predict how the full size model will look without going through the expense of creating the full size model.
  33. #473
    Largo, Florida
    Transverse? Electric?
    I'm curious about the planned engine orientation for the high mpg model. I imagine that it would be very difficult for the West Philly groud to shoehorn in a GTI into an 818 in the longitudianal arrangment. This brings up the question, if the 818 could accomodate a transverse diesel, what about other transverse engine options. I know that this has been brought up before. I'm just daydreaming with the thought of an ultra lightweight, 400+ hp Hartley V8, or even a lighter weight, ultra-cheap, 200 hp Hayabusa 4 cylinder.
    Also, the West Philly "EVX GT" had an electric motor on the front wheels with regenerative braking. Is the 818 being designed with that as a possibility? Since I'm just day dreaming here, and money is of no regard in this dreamland, I'm imagining a 2000 lb 818 with 400+ hp on the back wheels with an 8 kw*hr battery driving an electric motor with about 100 hp to the front wheels. That would be an awesome hybrid.
  34. #474
    Member Justen's Avatar
    Cranston, RI
    Many of us feel the same way, but the chassis may change before it is finalized and there will be different roll bar options as well for each body style.
  35. #475
    Senior Member D2W's Avatar
    Spokane, WA
    Quote Originally Posted by Silvertop View Post
    By X-818-R I'm assuming you mean Xabier's race version. I could be wrong but to me his race version is his regular car, lowered/short windshield/louvers on the rear cowl, and a paint job. There may be more, but these are items anybody could do for the same effect.
    I can do anything with enough time and money.
  36. #476
    Forest Lake MN
    Quote Originally Posted by D2W View Post
    Yes, I'm referring to Xabier's race version. And you are right, it wouldn't take very much to transform the street version into the 818-R. Which is precisely the point. It means that it also wouldn't be all that difficult to prepare a 1/4 scale 818-R model alongside the street model that we already KNOW is being prepared. And we know that Dave Smith is particularly partial to the race version.
    I'm not really saying that they have actually done that. It's probable that they have NOT. But they COULD have. A lot of folks would probably like to see that done up in a 1/4 scale model. And it's fun to speculate.
  37. #477
    NYC
    Beg to differ. Having done some half-assed clay modeling (and having a decent art/clay background), I can tell you emphatically that the RISD model was not easy to prepare, so preparing a race version wouldn't be either.
  38. #478
    Forest Lake MN
    There you go trying to confuse me with FACTS!
  39. #479
    TDI Powerplant
    Dave,
    The West Philly High School Popular Mechanics article mentioned, "The TDI technology in this car is slated to become part of the new Factory Five 818 product line-up." Will this be an option in Gen 1?
  40. #480
    Chevy is adding a diesel powertrain to the cruze as well. More high MPG oil burners FTW!
