Results 1 to 8 of 8
Thread: help please
    Senior Member jwhit's Avatar
    Oct 2019
    north carolina
    help please
    my kit came with gas pedal but it doesnt match any holes on the steel bracket for the gen 3 can anybody share a picture of theirs or tell me
    how yours went in
    thanks
    Senior Member Alphamacaroon's Avatar
    Jan 2019
    Richland, WA
    I assume you are not installing a Coyote engine? I installed a Coyote so I might not be much help, but I know mine came with the bracket on the chassis and then another separate bracket that was stainless steel (maybe aluminum), that doesn't get used with the Coyote pedal. Are you talking about the bracket welded on the frame, or the separate metal bracket?
    --jim
    Build 1: Gen III Type 65 Coupe, Gen II Coyote
    Oct 2019
    north carolina
    Quote Originally Posted by Alphamacaroon View Post
    not coyote just old school windsor mine has steel bracket welded to frame doesnt match manual but the pedal i got does look like what is in book
    just does not line up with any of the holes
    Livermore, CA
    You'll just position the pedal where you want it and drill holes to mount it. That's how it's intended to be installed so you can get it where it's comfortable for you.
    Senior Member UpNorth's Avatar
    Jan 2018
    Baie Saint-Paul, QC
    Go see P100DHG build thread, post #67. It might help.
    Jan 2018
    Baie Saint-Paul, QC
    Or The Colorade « Coop » build thread, post # 44. Might give you some ideas.
    Oct 2019
    north carolina
    thanks guys for the help ,now i get get plan on were to mount mine
    Top Notch Builder P100DHG's Avatar
    Pasadena, CA
    Check out my build I have a table of contents that will guide you in pedal placement and accelerator cable routing. Link is in my signature
