Results 1 to 18 of 18
Thread: Weather Pack kit
    Senior Member lahrs37's Avatar
    Jul 2014
    Philadelphia
    Weather Pack kit
    Is there a recommended weather pack kit that will be enough to do all of the roadster's lighting/signals/etc.? Specific links would be appreciated!
    5.0 HO from a '93 Mustang, SVE heads, Trickflow stage 1 cam, Trickflow Street Burner intake manifold, T-5 w/mid shift, IRS
    Delivery 9-10-16, First Start 12-28-16, First Go-Kart 2-18-17
    Build thread: http://thefactoryfiveforum.com/showt...MK4-8951-Build
    Jul 2014
    Philadelphia
    Order sent! Thanks!
    Get the crimping tool you will need it!
    Jun 2015
    Fairfax Station VA
    Hi Lahrs,
    You've probably already got a good set of regular crimpers, but for others' benefit I'll recommend these: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1. They have interchangeable jaws that allow you to crimp Weatherpak, insulated, and non-insulated terminals up to 10 gauge. I love mine.
    MK IV Roadster #8631
    Jul 2014
    Philadelphia
    Thanks guys. I will snag those crimpers too!
    Senior Member Paparazzi's Avatar
    Jun 2014
    Hopewell Junction, NY
    Get one of these too, you'll likely need it. I made a couple of 'mistakes' and also changed my mind a couple of times.
    https://www.amazon.com/Delphi-Packar.../dp/B000IIY56E
    I really think that you should ship one of these with your crimper, Mike!
    FFR6243RD, MkIII, 3.55, IRS, pin-drive width, carb'd 351W, T5, 1/2 dropped butt, Fortes hydraulic clutch, deep dish AC-III wheels by Team III. 9 year build; NY registered 7/18/2016 - "Sweet 16" winner at 2016 Taconic State Nationals 5 days later ... in 'rough as hell' gel coat for the foreseeable future! Build Blog - Leave me a comment!
    Register your car with the Factory Five Cars Rule! mobile app available from the app store
    Jul 2014
    Philadelphia
    Quote Originally Posted by Paparazzi View Post
    Will do!
    Folsom, CA
    Todd
    Dublin, OH
    get the $38 one. it has a guide on the back that holds the connector pins in place while you crimp. make sure you don't put too much pressure on the wire as I've pushed the wire beyond the crimping zone, resulting in the crimp occurring on the wire insulation. I'm sure it would have worked just fine since the distal bare wire was still touching the metal pin, but cut them off and redid them anyway.
    Colorado Springs
    This is also a good source for components.
    https://www.diyautotune.com/shop/wir...her-pack-kits/
    .boB "Iron Man"
    www.RacingTheExocet.com
    O'Fallon, MO
    I have the cheap crimper, it works fine, but it is slow and tedious to use correctly. Had I found the better crimper 6 yrs ago, I'd have it instead.
    Folsom, CA
    oh good idea - plus it comes with the removal tool as well!
    Todd
    Don't the weatherpack connectors come with the kit any longer? They used to include all the ones needed for the front and rear t/sig's..
    Dublin, OH
    nope
    Folsom, CA
    Quote Originally Posted by Bob Cowan View Post
    wow - so many choices!!!
    Todd
    Senior Member ggunter's Avatar
    Jun 2020
    Rising Sun , Md.
    Does anyone know what the weather pack amperage ratings are for their connector pins?
    Jun 2015
    Fairfax Station VA
    Quote Originally Posted by ggunter View Post
    20A max. https://www.wiringdepot.com/jt-t-tec...-Terminal-FAQs
    So if you're using a fan with a 30A fuse, the weather pack connector becomes your fuse!
  19. Likes toadster liked this post
