A prototype 6R80 trans mount and crossmember
Prototype 6R80 trans mount. When I pull the motor out (hopefully next week), I will cut off the FFR trans mounts from the frame. Then I’ll set motor back in, get the angle right and trim the long edge of the crossmember, leaving some as a gusset.
After I see how it goes in again, I may weld the crossbmember in then cut out the center and leave tabs on the frame. Then make another plate that is a removable crossmember. I don’t think it’ll be necessary though, since the mount is on the back of the trans case instead of bottom. The flange will have to be up and above the crossmember when going in before it reaches it anyway. Once I’m sure of that, I’ll decide weather to make the crossmember removable or not. Worst case, I cut it out later, remake it to mount from the bottom and use spacers to her back up to right angle.
This is the back
![](https://i.imgur.com/6cz8LnO.jpg)
Front. The two empty holes is where it bolts to the trans. The line is just a reference. I’ll trim off even with bottom of frame tubing once I know exactly wheee it has to go to get angle correct.
![](https://i.imgur.com/gvrksWo.jpg)
For those interested who didn’t see in build thread, the 6R80 goes in with no problems. The back of the pan sits on the frame mounts from FFR. The angle like that isn’t quite enough (just shy of 2*). But nothing else is in the way.
'33 Hot Rod
MK4 Roadster
Thanks for posting this, and thanks for blazing the trail for those of us who may want to use the 6R80. A bookmark for this thread is going into my "build notes" folder right now.
Keith
Sure thing, Keith.
I’ll also post 6r80 content here as well as build thread. Hopefully I’ll have the mount finished next week or week after (depending on how long the wife’s honey do list is for Jr’s first birthday party lol). After that, will be a break before find out if converter or gearing is on point
'33 Hot Rod
MK4 Roadster
I'll most likely be doing something similar too. Haven't got the engine/tranny in yet (hopefully next week) however I have the same tranny mount as you Svt and it doesn't align to the tranny (4L65e) mount holes either.
Here is a photo of the trans in the car. You can see that the threaded holes are quite far to the back of the case. Hoppefully that will help me not have to make the crossmember removable. As long as there is enough room to get the trans up high enough to clear it while going in before getting that far back. I’m fairly certain after the initial install that it’ll be fine.
'33 Hot Rod
MK4 Roadster
JimLev
Jim,
This is the trans mount I used from Amazon. Prothane 7-1604 Red 6 and 8 Cylinder Transmission Mount Kit You just have to shim it foe height. (about 2 inches)
HVACMAN
Jim,
Thanks Andy.
I spoke to Tony earlier today, he said the one they ship is for a Ford tranny, us GM guys need to get our own.
I contacted Lokar today and they do have a 6R80 compatible shifter. It also has a manual/sport mode. Manual mode doesn’t work with the Ford ecu they say, only with aftermarket controllers. Sport mode should work, assuming you use a donor ecu and keep the harness to the factory shifter. Using the M-9000-PMCA motor/trans/control package, or just the controls pack from ford for a donor engine/trans, I don’t know if sport mode will even work. There is no extra input in the harness to the stripped down ecu. The shifter will work for P-R-N-D, says lokar. I am going to contact FRPP and see if there is even a sport mode in the ecu (like in the mustangs) or not. I also am curious if the ecu has the ability to have a “manual” like mode where the mustang paddle shifting could be turned on by a tuner. It would be cool to have the forward/reverse manual mode work like the paddle shifters in the mustang. I don’t expect to be able to, using the stripped down controls pack ecu, but I’m going to ask the questions and maybe even poke around with the tuner when the time comes.
'33 Hot Rod
MK4 Roadster
Updating information found. The ecu gets its trigger for sport mode from the transmission. The cable from the shifter moves the lever on trans into a position past drive and the ecu sees that through the large plug. Not via a switch on the shifter. This might make a fully manual mode unlikely. But downshifting will still be possible (or upshifting if you want to do it earlier than ecu) will work. I’ve got more to look at, and the right shifter could do it, but I don’t know that one exists or can be made to work.
Another delimma to sort out. The lever on trans has 7 positions. I expected 5 (P-R-N-D-S). So not sure what those two others are. I need to pill the factory stang shifter and see how many it has.
'33 Hot Rod
MK4 Roadster
Update research info.
Found two places that will make the driveshaft. Using flanges on both ends and they’ll put a splined slip yoke in the shaft itself. One online and one local. Not sure of boards policy of non supporting vendors do I won’t post publicly but all you have to do is call and ask, it seems. Wasn’t very hard to find at all. I think I’ll jse the local guy. He’s made 3 so far for me (two FFR cobras and a t bucket one) and never had any trouble.
'33 Hot Rod
MK4 Roadster
Update. The trans tunnel fits without much headache.
I got the trans tunnel in. It actually fits over the 6R80 easily. Making this transmission fit has been much easier than I expected it to be. Will be trying foot room later today. I also ran the main engine harness to the relay box through the top left of the tunnel.
![](https://i.imgur.com/IYZ0YYk.jpg)
I did take the time to Install rivnuts in the front face of the tunnel and use the same bolts I used for the firewall to attach it. Makes it a bit of an order puzzle to assemble but it sure looks cleaner than rivets from the inside and will make sure it stays sealed.
'33 Hot Rod
MK4 Roadster
Consummate Learner
Svtfreak
...I did take the time to Install rivnuts in the front face of the tunnel and use the same bolts I used for the firewall to attach it. Makes it a bit of an order puzzle to assemble but it sure looks cleaner than rivets from the inside and will make sure it stays sealed.
Curious why you wouldn't put the rivnuts on the firewall and then screw the tunnel down to that. I wouldn't think the ends of the rivnuts would be very visible behind the engine, and you wouldn't need to have double jointed wrists and fingers to get behind the engine to remove the tunnel.
Mike, you’re right. They wouldnt be very visible. But they would be. And I’m trying to really take this build to the next level of details like that. Honestly, a couple rivets would work just fine. And, accessing them actually isn’t very hard at all. The top one on reach side is worst, and can still get a hand in the do it. My short pattern Allen’s get back there and tightened them quite easily.
'33 Hot Rod
MK4 Roadster
After bit messing with trans stuff for awhile, it’s time again. I’ve ran the car and filled it in park. I cut an access hole in the tunnel to fill it for now. Being a sealed trans, now I shouldn’t have to mess with it h til I change fluid and that’ll be awhile. I’ll do that on a lift. I’ll glass up that hole one day.
The 6R80 transmission doesn’t use a slip yoke in the output. It has a flange. FFR doesn’t support this trans yet. So, after calling several online driveshaft shops as gasping at the price, I called my usual dude. He can make the driveshaft with the splined yoke in it, balanced and ready to bolt in for a much more reasonable cost. Still quite a bit more than the normal style shafts lol. So, I brought him the two flanges I have (one for each end) and the one new u joint I sourced from the FFR driveshaft. They have to order the parts for the slip yoke but said it should be ready by middle of next week. Another hurdle sorted and hopefully solved. I think that was the last “must have” hurdle, and everything else is “this’ll make it real cool” hurdles to make this trans work.
'33 Hot Rod
MK4 Roadster
Put it in today. Ready for first go cart tomorrow I hope! I will have to brace the mounting surface when I take the tunnel out. I used rivnuts as the bolts where not long enough.
![](https://i.imgur.com/RB7enhO.jpg)
I did have to reangle the bracket to clear the frame.
![](https://i.imgur.com/ircSvlD.jpg)
Installed and done. Will have to put a keeper to keep cable out of driveshaft. Otherwise works wonderfully. The side movement for up and down shift is real neat. Can't wait to wire that up and try it.
'33 Hot Rod
MK4 Roadster
Converter news!
Using power brakes (I have the ABS electro hydraulic system), the frpp crate setup converter is perfect! Not too much brake force needed to keep the car stopped. Let off and car moves. I am very pleased. With no power brakes, though, you may consider a slightly looser converter.
'33 Hot Rod
MK4 Roadster
Sport Shifter With Factory PCM
I've been following your build with much interest. Thanks for the 6R80 installation information. I too am installing a Coyote and 6R80 with Lokar shifter.
Were you successful getting the Lokar shifter sport shift mode to work with the factory PCM? If so, I'd appreciate some details.
Thanks!
I haven't attempted that yet. Honestly, ive kinda gotten side tracked with a bathroom expansion and remodel and catching up around the house. Pressure washing, etc. The next step is to get the blower on and get it tuned right, then later on I'll make attempt at those. I make no promises when, but I will be playing with that later. I put that aside when I couldn't find a wreckes 2015-18 Mustang to steal a computer plug from and can't seem to find anyone who knows what pins I'd need to attain to plug into the harness properly. But when I do, I'll Def be posting that here.
'33 Hot Rod
MK4 Roadster
I have a lot to do before I tackle that task myself. I'll let you know if a get it figured out. Thanks.
'33 Hot Rod
MK4 Roadster
I am also using a 2nd Gen Coyote with the 6R80, but in my case in a 1970 Mach 1 restomod. I contacted Ford Performance and obtained a pin out for their controls pack. Yes the controls pack for the 2nd Gen Coyote for use with the 6R80 supports the sport shift mode, or so they said.
Reason: reordered attachments
Alan_C
Thank you very much for this information! I'm using a 2012 PCM, so this may not work, but I'm going to give it a try. Please let us know if you are successful.
You’re 2012 pcm pin out is very likely different.
I have the same pin out. Power by the hour has verified that it does and will work. I’m going to hook up the Lokar switches to those pins and use it as a back and forth down and up shift function. They said they aren’t sure if the true sport shift as in the mustangs will function (and ford hasn’t and won’t say which pins to actually put it into “s” mode).
'33 Hot Rod
MK4 Roadster
I have the OEM 6R80 shifter and can determine which wire in the shifter harness is for the "S" sport mode. I plan to buy a Mustang GT electrical diagram and will then trace back the wire path to the ECU. It is going to be a while before I get into my wiring, so if one of you figures out the sport shift wiring in full, please post.
Alan
Alan_C
Alan
Sport mode is not activated in the shifter. It moves the trans lever to a sport mode position and the signal is sent from the trans to the ecu to enter sport mode. It is done on a canbus communications system. Same with neutral safety switch. The people who knows say that you cannot force the controls pack ecu into a sport mode. One tuner has confirmed this with me. However, you can use the upshift and downshift function. Ford makes the pin out for the controls pack ecu available. I will be making this part of my Lokar shifter work. I plan on working on that soon. I have to get the pins to tap into the ecu plug
For those going down this path, I have learned that the stock mustang converter, which is supposed to stall at 2800ish rpm, is just too tight. I have confirmed this with one other person who has this setup in a very similar weight car to the hot rod and they had the same problem. I swapped to a 3400 advertised yank (brand) converter. A circle d is also a good bet and well known in the mustang world. And now the car acts perfectly. It’s even still a little tight when cold but after it warms up some, literally 1/4 mile down my street at almost an idle and still not the full weight installed in the car, it brakes and stops easily with manual brakes.
'33 Hot Rod
MK4 Roadster
More 6r80 details!
Finished up the shifter mount. Welded two tabs to the trans crossmember and the mount brace bolts to those. It’s rock solid, out of the way of the driveshaft flange and the wiring will be easy to keep out of it also. Then I cut out the tunnel for it. Since this pic, I trimmed the cable stay down and gonna patch up the slit I cut in the tunnel. Now it sits slightly lower, the bracing and cable stay will now not need to be bezeled and trimmed around. Should make it look cleaner for the final assembly.
![](https://i.imgur.com/Sz9kCyK.jpg)
'33 Hot Rod
MK4 Roadster
Next, use a pick from the front and push the plastic pins out of the back enough to grab them in the 3 positions noted in instructions. Then pull them on out.
![](https://i.imgur.com/HGgaFtt.jpg)
Now, you insert the new pins in the same orientation that all the other pins are. The spring pressure tab should be facing the same way. Push each one in until it clicks. I think it’ll only go in one way. Finished, it looks like this and they should be flush with the front.
![](https://i.imgur.com/fLScIDj.jpg)
Reinstall the white front cover, the black strain relief in the back, running the new wires in the harness. Tape it all back up. You can then decide how to run the 3 new wires to your switches. I went along the body harness (I will put it in the harness when I pull it all out for paint) and will jump out where it goes into the car and run a new loomed leg to the switches. You can use any switches you want. Console mounted momentary buttons or even some sort of paddle on the wheel.
I fired it up and tested and seems it’s working great on the jack stands. One day I’ll go try it out in the street.
'33 Hot Rod
MK4 Roadster
Thanks so much for sorting out the wiring to the ECM connector. I went on the PBH website and kept looking for the Select Shift Pin Out Kit. I finally found it under adapters and electrical parts. Now to start work on a shifter mount similar to yours.
https://pbhperformance.com/product-c...ctrical-parts/
Dreamer
Have you made any drawings of the mounts for the transmission and shifter? Would you mind to share them?
Robert
In case you want some options, I went down a slightly different path. I used the FFR supplied transmission mount with a cut down piece of 2.5" steel angle. The 6R80 ended up at the correct -2° angle on the first try.
I went the erector set route for the shifter mount since I used the shifter that came with my Coyote Power Module. Sorry, no drawings available. If you want to go this way you can PM me and I'll take some measurements for you and/or send more photos.
Keith HR #894
Dreamer
looks likes a meccano box....
Svtfreak: You appear to be the furthest along of anyone using the 6R80. Can you tell me if the 6R80, engine harness, and controls pack have a neutral safety switch function built in? I have this question into Tom at Ford Performance, but no reply from them yet. Trying to determine if the neutral safety switch function is implemented by the transmission shift level position, like the sport shift function, or if Ford senses the position from the OEM shifter? There were wires going to the shifter assembly, so it is possible they did it in the shifter. Ford won't share the wire/signal list for the engine harness connector on the PCM, I have asked twice. The only wiring information they will share is the controls pack, body harness, connector data. FP did point out that the clutch bottom of travel switch and our Lokar shifter could be used to implement one, however I do not want to do something redundant to what may already be there.
Alan
Alan_C
Alan
Hey Alan. Yessir, the 6r80 when connected to thr controls pack ecu does already have a neutral safety switch in it.
I tried to reply to your pm but getting an error. Please pm me your email address and I will email you directly.
'33 Hot Rod
MK4 Roadster
