Good morning, I did not receive any responses on my build page so I thought I would post the question here. Has anyone had trouble with the installation of the fuel tank side covers? The manual (version 3G, page 397) tells you to install them prior to installing the door hinge brackets. I found that the door hinge bracket interferes with the panel when installed (as the pictures show). Gen 2 build. Thanks Ray
I did test fit them a while ago, let me look at some of my pics, more later.
I put mine on after the doors and body were on, then took them off so I could pull the body.
I drilled and tapped the frame to make them easy to remove.
Mine are 19.375” long.
Sorry, I don't understand Ray.. I'm doing doors now too, and page 397 is a good 30+ pages after the door hinge brackets are installed.. what am I missing?
I'm at the same step...I believe the attached pics is how it goes. I think it's meant to sit so when the door hinge bracket is at it's highest adjustment point this side cover would touch the bracket. I have a 3H rev manual but the same pic as mentioned above....if you look at the pic from the manual they show it sitting higher than the hinge bracket which is why I think it sits like the pics I show. The only thing I'm not sure on is how high it sticks up above past the trunk hinge bar
I could be wrong. i have not put the body on yet but I can't envision how you would drill & rivet or tap these with the body on.
Morning, let me explain further. First the picture on page 397 shows them attached to the frame without the hinge brackets installed. They would fit this way. Now if you look at the picture below that 33fromSD posted you will see that the rear of the panel extends way beyond the trunk hinge bar. This would interfere with the body installation as the body fits flush with the trunk side panels. (Jim I also drilled and tapped them so they were removable for the body install and this was the only panel I neglected to test fit prior to disassembly for paint). After I painted the car I attempted to install them but there was no way I could get them to fit. I might be missing something but I think the only way they would fit is if they were shorter. Tip: if you tack the nut on the door opening stop allen bolt to the hinge bracket the doors are really easy to remove, its hard to get the nut started on the stop bolt after the body is installed and its hard to remove the doors with the stop bolt installed. Thoughts? Thanks Ray
Thanks Ray...... I'm pondering leaving mine in the general vicinity that I have them and either trimming the top to match the height of the trunk hinge bar or bending them down the same angle as the trunk bar. I'm somewhat certain my first pic is correct on the lower positioning. The only other way to do it is to cut a notch in the lower portion by the hinge bracket and bring the top down to the correct level of the hinge bar.
33fromSD, thank you for posting the picture. Before you start cutting the panels I would wait and see if maybe I am missing something and someone else on the forum will show us how they got them to fit. I believe that you have them installed correctly, its the rear height of the panel that seems to be way off. The picture of the installation on page 397 shows them even with the trunk hinge mounting bar as far as I can tell. Ray
I’ll have my roof and water fall pulled out in the next 4-5 days, will see what it looks like with the pieces in place and snap a pic.
From what I remember I didn’t have any problem sliding them in place.
I'm not sure if they are supposed to be, but your Gen 2 door hinge brackets are mounted a lot higher than the Gen 1, and appear to be made upside down from the Gen 1. If the door hinge brackets are correct, then the panel design may not have been changed for the Gen 2. Maybe?
That's a good possibility HVACMAN....... The good news is after installing the body on the chassis yesterday the first thing I checked is how close were the hinge holes I made in the body (based off the template) and they are dead on with the hinge bracket mounted in the chassis so that at least is good.
The bad news is either these are the wrong fuel tank side panels or if they are right they need to be trimmed somehow since they are not going to fit.
I've pinged David at FFR and sent him some pics, hopefully he can clear this up.
So I'm not sure there is an easy answer to this yet. I pinged David again today to just make sure he got my note yesterday with the pics I sent. He said he got them but he was waiting on a response from engineering. Normally David has an immediate answer for everything I've pinged him on.
33fromSD, I am glad you got with Dave. I also e-mailed him several times but he couldn't understand my problem. I think its because my pictures are not as good as yours. I messed with the panels again this week as did 3 of the other mechanics at the shop and nobody could get them to fit. I think they are just too long. Ray
My panels did not fit either and I needed to trim them back to fit with a small gap, I then added a foam rubber seal between the edge of the plate and the body to ensure no gapping and no "point" pressure from the plate to the body that could wear over time. 20200509_135707[1].jpg I also used it to mount my crossover for the stereo as its protected there and keeps less stuff in the door.
Andreas
Yup... just got a response from Jesper (Director of Eng) at FFR...here was his response .....
"Those are the correct mounts and in the right place. They are oversized a bit. Put the body on first then weatherstrip around the panel and put them in. Trim if necessary. "
Maybe to cut down on some of the road noise???
I’m going to insulate the top and bottom of those panels.
