Results 1 to 4 of 4
Thread: 818C Bushing Opinions Please
    Mark Eaton's Avatar
    Medford, Oregon
    I have a 2006 Impreza donor which had over 150,000 miles on it. The suspension components and bushing didn't look bad but I figure I should replace the bushings. Here they are
    I have pretty much decided on Polyurethane instead of OEM bonded rubber bushings. The most recent threads I could find on this subject was from 2016. I'm just curious if anyone has any advise? I'm planning on purchasing a kit from Suspension.com.
    https://www.suspension.com/kit120k
    The other issue on this subject which I have been considering is to install Zerk fittings in the housings. I haven't seen anybody post about this but with out zero fittings I'm not sure how to lube them without taking them apart...
    I ran the OEM bushing for a while. since the car is only 2000# the were plenty stiff for the application.
    In the rear, I switched to all swaged tubes and rod ends for adjustability.
  3. Thanks Mark Eaton thanked for this post
    Mark Eaton's Avatar
    Medford, Oregon
    Where did you get your swaged tubes? And what kind of bushings are you using on your front LCA?
    I think I bought them from Speedway Motors. I believe FFR also sells them as an upgrade part.
    I am running OEM bushings on my LCA. The chassis alignment on the LCA isn't perfect. If you put stiff bushings in, you might have problems getting the LCA to fit.
