Thanks Thanks:  2
Thread: My axle contacts the panhard frame mount
    Oct 2020
    Albany, NY
    I’m a bit confused. My frame had a gap like shown. I drilled like the instructions say but when you tighten it it pulls it in. Then it contacts the axle. The picture show the gap now. One example I tighten it up it pulls it in then contact is made. I have the shocks mounted in the lower hole on the upper mount.
    I can use some advice
    DFF90955-5E43-4AF6-A408-13748A5C4C1E.jpg. 3E333DD8-0478-4DDB-8F3A-BB65583B8CBB.jpeg ACF135B1-8D54-400B-ADE9-CBA8AE3535C0.jpg
    Build Thread https://thefactoryfiveforum.com/show...been-delivered
    Oct 2020
    Albany, NY
    Oh man, I had my upper link too tight. I apparently just needed to freak out on the forum to see it
  3. Likes RoadRacer liked this post
    If you have the axle hanging at full droop it will contact the panhard mount tube that runs forward to the round tube.
  5. Thanks Blitzboy54 thanked for this post
  6. #4
    Oct 2020
    Albany, NY
    I’m so relieved, Thanks Jeff. I took it apart twice. Since I have your attention what are these for? I went over the manual 10 times, they are my only leftovers from the 3 link HW kit. I had a longer one for the upper bracket brace, but I can’t find a home for these.
  7. #5
    Jan 2019
    Long Beach, CA
    I had those left over too.
    Ordered 9/24/2020, Delivered 1/18/2021 MK4 Roadster, 3 Link, 15" Halibrands, Blueprint Carb 347/TKX Installed 3/13/2022, first start 10/2022, go cart 11/2022, CA SB100 Reg Complete 12/2023
  8. Thanks Blitzboy54 thanked for this post
  9. #6
    Oct 2020
    Albany, NY
    Quote Originally Posted by Daddy O View Post
    Outstanding
  10. #7
    Senior Member hineas's Avatar
    Colorado
    Yes, at full drop the axle rests on the mount. Mine does it too. You can see we have a rag between the axle and the mount where it makes contact.
    I also had those two bolts left over. I ended up using them to mount the pedal box to the front of the foot box because I was missing those bolts and they are the exact same bolt!
    Mk4 Roadster with BluePrint 347 with Holley EFI and solid axle rear end.
    Build thread
    Body work and paint thread
