Hey All,
I've run into a little issue as I'm trying to get the engine/trans position and driveline angles dialed in, and would appreciate some input. I added 3/4" of spacers (Forte's spacers) to the trans mount, and my initial measurements show that pinion angle is good. However, the problem I'm seeing is that the transmission is angled toward the passenger side of the trans tunnel, resulting in the driveshaft being angled laterally from the tail shaft to the IRS. I can't imagine this is good. The problem appears to be the rather large collar on the Pro 5.0 shifter that I purchased along with the TKO600 from Liberty's Gears. If I jack the transmission up so that the collar on the shifter is above the diagonal brace in the trans tunnel, I can align the transmission properly but at proper height the collar (and the throw adjustment bolt and jam nut) interfere with the diagonal brace. Note that this is in the rear shift position. I've seen a number of folks having interference with the other diagonal brace when doing a mid-shift position, but I've never heard of interference in the rear shift position. So I figure my options are:
1) leave the transmission pushed to the PS to fit the collar. (Can't imagine that this is the right answer).
2) Cut and reinforce the diagonal brace to accommodate the collar (this doesn't sound fun with the engine/trans already in the car - and no, I'm not removing them).
3) Replace the shifter with a different shifter that doesn't have a ginormous collar on it. Any recommendation? Just go back to a stock Tremec shifter, or are there other aftermarket shifters that are lower footprint?
4) something else entirely that I haven't thought of?
Here are a couple of photos that show the issue. Note that in these photos the transmission is still angled a little. If the trans is straightened out properly, the collar is actually over the 3/4 tube.
