If you would like to mellow out your roadster a bit, and are particular about quality, then a set of all new QuietPipes baffled side-pipes may be just what you are looking for. If you don't want everyone within 150 feet to turn and look at you when you start your car at the gas station or coffee shop, then a set of all new QuietPipes baffled side-pipes may be just what you are looking for. If you would like to take your Roadster to church on Sundays, then a set of all new QuietPipes baffled side-pipes may be just what you are looking for. We think in many cases a Roadster with Quietpipes gets used and enjoyed more!
![](http://thefactoryfiveforum.com/attachment.php?attachmentid=60619&d=1478456601)
Close-up of Quietpipes collector. Notice the high-quality welds and collector shape.
![](http://thefactoryfiveforum.com/attachment.php?attachmentid=60620&d=1478456602)
Tight radius bends increase clearance to rear edge if body cut-out.
Check out this video for a sound clip from Todd Buttrick's 392 Stroker. The dog even likes it.
These pipes address the need for neighborhood friendly side-pipes. The outstanding feature is the baffled design with no packing to blow out. These side pipes will be as quiet after years of use as they are the day you installed them.
The sound is sweet and powerful but never nasty. Have we made them too quiet? Maybe. 70mph cruise wind noise is a bigger issue. These pipes are made to order in USA with all new parts so you don't have to sacrifice your FFR loud pipes, or search for a donor set, or incur an outbound shipping cost.
The collectors make a smooth transition and are a nice cosmetic improvement over the FFR collectors. Warning: once you see the smooth collectors, you can't un-see them! Also, check out the improved weld quality. The width of the welds at about 3/16" is about half that of typical Factory Five welds. The FFR collector is the cut-off pipe in the main photo. Our design also removes the FFR kink in the passenger side, meaning the 4 tubes, collector, and muffler section are all on the same axis. It just looks better. The pipe bend radius is smaller which provides more clearance where the sidepipe exits the body. The turnout has about 1" of extension for a more finished look, and angles down slightly towards the road.
Plan for 2 - 3 weeks for delivery. Add a week for transit time if you are on the West Coast.
Notes:
- Photo shows collector with the smooth collector you will receive with your all-new QuietPipes.
- Pipes come with Mk3 style two-hole mounting tab. Note in special instructions if you need a Mk2 style mounting arm.
- If you install your pipe with gaskets, you must remove the unsupported center section "star" of the gasket before installation. If the center is not removed it will eventually blow out and is likely to get stuck in a baffle and cause unwanted sounds.
- These pipes are fabricated in carbon steel only. Customer will need to paint (high heat black is our favorite) or have ceramic powder-coated locally.
Click here to visit our website and order.
