Thread: Braided hose at top of engine?
    Bolton, Ontario, Canada
    What is this for? Mine is plugged at the end that I'm holding, and then is just visible where the arrow is. From that point it seems to go downwards.
    Thank you,
    Rick
    Ted G's Avatar
    Aug 2021
    El Dorado Hills, CA
    My guess would be a vacuum port
    Syracuse, NY
    Not a vacuum port. Most likely an oil pressure tap. The original WRX owner most likely has an aftermarket oil gauge installed. With the motor off, unscrew the plug and you should see oil drip out.
    Be sure to put it back before starting the engine.
    MK3.1 Roadster completed 2011
    As long as it is not something stock that I should have connected. I'll try and see when the car is on the lift where it goes.
    Syracuse, NY
    That is definitely not stock.
    Label says "Earls"? It looks like previous owner ran a brake or clutch line to the rear oil galley to tap for oil pressure. Should look like this at the block (minus the sensor):
    The galley plug should be M18-1.5 if you want to blank it off.
    I'm OK leaving it as-is since it isn't leaking. I can't see where it is going as there are other hoses in the way. The oil pressure tapping makes sense.
    Thanks guy.
