Results 1 to 8 of 8
Thread: How to fill holes in the firewall?
    Sep 2022
    Huntington, IN
    Any y'all filled unused holes AKA: mistakes? How or what do you use to fill in unused, unwanted holes? I was thinking JB Weld or some kind of aluminum patch? I'm looking for suggestions here. Thanks
    How big are the hole(s)? Regardless, I probably wouldn't use JB Weld. For small holes, a polished (SS) round head screw looks decent and gives the impression it's there for a reason. Larger holes, I'd probably go with a patch. I get it. Everyone likes a nice firewall on the hot rod (or truck) and especially if not installing a hood. But keep in mind, once done, it's relatively busy and much of the view is covered or at least obstructed by the engine and related.
  3. Likes Just 1 More liked this post
    Sep 2022
    Huntington, IN
    2 holes are 1/4" or 5/16" and the other is around 1/2". I thought about the stainless bolts for the 1/4" but the 1/2" one i'm not so sure of, Though maybe a simple rubber plug. BUT, like you said, once it's all done, I doubt it would be noticable.
    How about panel/hole plugs or sealing grommets? Lots of sources and sizes available.
    Senior Member ydousurf's Avatar
    Feb 2019
    Greality, Colorado
    J1M, ebay has many options from rubber to steel. There are metal polished one's w/clips that just push-in and you're done.
    Doug
    Dj or Doug or TheLateDude
    ----- #19 of 25th Anniversary MKIV 9769 -----
    Build Link: https://thefactoryfiveforum.com/show...-Slow-Progress
    Ordered: Oct 07, 2019 / Production: Dec 28th, 2019 / Shipped: Jan 19th, 2019 First Start: In the future... / Graduation: Even further in the future...
    Kingsland, TX
    I had a measurement mistake and drilled a couple holes in the wrong place. Thankfully I know a few friends with TIG welders and asked one of them to weld up the holes for me, then ground them smooth.
    Jun 2018
    North Vancouver, BC, Canada
    I threaded the hole and put a screw in it Didn't make a mistake with a bigger hole but would use a plastic or rubber hole plug if needed.... many different brands, some on Amazon even.
    Gen 1 '33 Hot Rod #1104
    Sep 2022
    Huntington, IN
    Didn't even think of the metal hole plugs, going to stop by my neighborhood hardware store and see what they have. Thanks guys
