Thanks Thanks:  4
Results 1 to 22 of 22
Thread: Oil Pan
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    Oil Pan
    Folks,
    Anyone know if this oil pan fits and doesn't hang too low on the frame?
    Canton Racing Products
    15-660 For Ford 351W For Front T Sump Street Road Race Pan
    It says 8" deep and I think that means it sits too low.
    Yes?
    Dan
    Current BOM
    I just measured 3 cars in my shop yesterday for a customer with an upcoming build…when using Energy Suspension mounts with a Windsor anything deeper than 7.5” will be below the frame rails.
  3. Thanks cc2Arider thanked for this post
    Jan 2019
    Mead Colorado
    Thanks Jeff. That is what I thought. Pointer towards an oil pan that works?
    Current BOM
    Best price you'll find on oil pans;
    https://kevkoracing.com/pages/ford-oil-pans
    Ted G's Avatar
    Aug 2021
    El Dorado Hills, CA
    Check out Aviaid. Those were the original pans in the early cobras and daytonas. Great baffles. Little pricey, but good quality. I have a 6.5" deep pan. Here is a link: https://aviaid.com/shopsite_sc/store...ilpns_sbf.html
    Have to keep in mind what depth the oil pimp pick up sits in the pan.
    cv2065's Avatar
    I compiled a few:
    CP351LT-RR (champpans.com)
    F501-RR - 302F502-RR - 351WSportsman Road Race – KEVKO (kevkoracing.com)
    Canton Racing Products 15-694S 351W Ford Oil Pan
    Moroso 20534 Moroso Wet Sump Road Race Baffled Oil Pans | Summit Racing
    Raleigh NC, OIB NC
    I got one of the MOROSO pans along with its matching oil pickup tubing.
    Kevin
    MKIV #8234
  10. #9
    Jan 2019
    Mead Colorado
    The engine may have the 649s on it. Thanks all
    Current BOM
  11. #10
    Senior Member Jonathan D's Avatar
    Jun 2012
    New Brunswick, Canada
    Good post as I was thinking the stock pan would work just fine.
  12. #11
    Quote Originally Posted by Jonathan D View Post
    Define “stock pan”. If you’re talking Windsor from a Fox or SN95 it will. If you’re referring to a 4.6 or Coyote it won’t.
    When I bought my MkII from the original builder I immediately started running autocrosses. About the 3rd AX I heard some engine noise so limped it home. Pulled the pan. It was a front sump w/ absolutely no baffles of any kind. And the rear wall of that sump was at about a 45degree angle up to the shallow end. My thought was that every hard accel the oil ran up that rear wall and it lost oil pressure. I had spun a rod bearing, so new rod, machined crank and bought a road race pan from Breeze. So a REAR SUMP stock pan may be OK but not a front sump.
  14. #13
    A stock pan is fine if you don't take the car on a track. These cars corner hard enough that you will push the oil away from the pickup and you'll be pumping air. Been there, done that, saw my pressure gauge drop to zero on a hard turn, while on the street, not even a track. That was on my 1st engine with a stock pan. I now have a Kevco, with trap doors, crank scrapper and windage tray, no more pressure loss, no matter how hard it gets pitched.
  15. #14
    Senior Member TBull's Avatar
    Dec 2011
    St. Louis
    I've been using the champ Road race gated oil pan for a 302 with great success on my last 2 builds.
    FFR #4402 MKII Supercharged 308 445 RWHP Sterling Grey W/ Black Sapphire Stripes, Purchase 8/22/2008 Sold 12/04/2018
    FFR #8249 MK IV "Milano" Kit purchased 10/5/2018 - In-Process with 3.27 IRS, Multiport, Fuel Injected Supercharged 347 Big bore with Coil On Plug running Holley HP engine management, 576 RWHP, 510 Torque
    https://thefactoryfiveforum.com/showthread.php?29980 Milano thread
  16. #15
    Senior Member Norm B's Avatar
    I too had a stock pan and saw bearing damage from hard cornering during back country road driving. I now have a Canton road race front sump 8 quart pan with all the bells and whistles. The engine mounts are are the mustang convertible type which, I believe, sit the engine a little lower. Made a couple of skid rails that are mounted to the bottom of the 4 inch round tubes. Protects the pan sump from speed bumps etc. Nothing is going to protect the pan if you centre punch an object higher than the rails anyway.
    HTH
    Norm
  17. Likes Jim1855 liked this post
  18. #16
    Jun 2021
    Colleyville Texas Between Dallas and Fort Worth
    I compiled a few:
    I used the CP351LT-RR (champpans.com). Good clearence. Works great and great customer service!
    Installed
    Newly retired, and first time builder and 5, now 6.. now 7 time grandpa.
    Boss Small Block 363 dyno 463HP, Holley Sniper EFI
    Build Thread https://thefactoryfiveforum.com/show...ing-a-Roadster
  19. #17
    Nov 2023
    I'm new to all of this...starting my first build with a donor car and engine is in the shop for overhaul. I see in the documentation that a shallow pan is needed, and this thread is very helpful. If all I am going to be doing is weekend joy riding, can I stick with the factory oil pan on a 2002 4.6L? It's rather expensive to get a decent shallow pan, pickup, pump, etc. Thank you.
  20. #18
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    Reach out to Mike Forte, he's got a 7.5 inch Moroso. (508) 875-0016
    FFR Roadster Delivered 9/16/21
    Forte 427 Fuel Injected with TKX Transmission
    Forte's Axle
  21. Thanks Gil Shearouse thanked for this post
  22. #19
    Raleigh NC, OIB NC
    MOROSO trap door pan. Mounted its above the frame rails. Use 8qts in it.
    Plate that covers the sump.
    Kevin
    MKIV #8234
  23. Thanks Gil Shearouse thanked for this post
  24. #20
    Raleigh NC, OIB NC
    Quote Originally Posted by Gil Shearouse View Post
    You will not need a new pump as the pickups are interchangable. Just buy the pickup matched to the pan.
    A pan hanging below the frame rails can be gone on your first trip to the supermarket if you hit a speed bump. My ride height is 4"X4.5" and have kissed some speed bumps moving very slowly. Frame rails kept all the expensive parts safe.
    Kevin
    MKIV #8234
  25. Thanks Gil Shearouse thanked for this post
  26. #21
    Jul 2021
    Tonganoxie, KS
    I am thinking about this pan for a 427 SBF build. I like the 'combo packs' Summit has for the MkIV. 7.5" depth. Thoughts?
    Milodon 31630 Milodon Pro Touring Oil Pans | Summit Racing
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, 427 Stroker (in the process of building it now), EFI System - Edelbrok Pro Flow 4, TKX, IRS, Wilwood Big Brakes
  27. #22
    Fairfax Station VA
    Like David, I went with a Champ Pan for my 302 https://www.champpans.com/products/p/cp302lt-rr/.
    I bought it from Gordon Levy. If you call Gordon & Mike Forte and ask their advice, you'll have your answer.
    MK IV Roadster #8631
