Thanks Thanks:  2
Thread: Electric power steering?
    Mar 2021
    Just curious if anyone has gone this route? Would the racks from more recent mustangs (2011 and on) Bolt into a Mk4 without significant modification?
    Senior Member F500guy's Avatar
    Aug 2022
    Portland, Oregon
    I did a Electric Power steering, after market not OEM. You can see the route I took in my build thread. OEM would be nice, I thought about my 2020 Miata EPAS would be cool, but I did not do the work to see if it would fit.
    MK IV Delivered June 27, 2023 Build Thread-https://thefactoryfiveforum.com/showthread.php?46069-Lance-s-Roadster-Build-Thread-Starting-the-Al-panel-slog
    "Build a Car" They Said "It Will Be Fun "
    Oct 2022
    I have electric power steering on my Speedstar. I purchased a Rugged brand unit from Demon Power Sports. It is the same motor as the one sold by FFR for less than 1/2 the cost. It works well in the limited driving I have done so far. It also has provisions to accept a speed input to make the assist speed sensitive but so far I haven't seen a need for it.
    The 2011 up rack will not work.
  5. Thanks Rian_Colorado thanked for this post
    If he says it, I'd believe it.
    Senior Member Rebostar's Avatar
    Jan 2024
    Check out my build thread. I installed an epowersteering.com unit, seemed to fit well. Uses the FFR manual rack. Does require welding. I have not wired it up yet, but the installation was straight forward.
    Rebostar
    Senior Member EZ$'s Avatar
    Feb 2014
    San Ramon, CA
    520 Speedworks offers electric PS, and they're a supporting vendor. Greg is also a great guy and easy to work with.
    Rick
  9. Thanks David Hodgkins thanked for this post
  10. #8
    Senior Member SJDave's Avatar
    Santa Clara, CA
    Here's my review of the Speedworks 520 or Epowersteering kit for the Cobra.
    Overall happy with the system. A speed sensitive system would be nicer if you track your car.
    https://thefactoryfiveforum.com/show...ghlight=sjdave
    PS - BE AWARE - The pins in the connector from the under-dash boost control have there way of working themselves out of the connector housing. I added some hot melt adhesive to glue them into the connector body.
    Mk 3.1 #6616 Complete Kit, July 2008 Start, Gromm Racing 347, TKO 500, IRS, Carmine Red / Wimbleton White
    Mk 3.1 #6756 Complete Kit, May 2016 kit completion, Smeding Alum. 427 Stack Injection, TKO600, Custom Silver/Blue (SOLD)
