0
0
Originally Posted by
BEAR-AvHistory
In the trunk on the upper shelf.
Ditto on the location with Kevin; however, I did upgrade the battery box with one that I purchased from Speedway motors.
https://www.speedwaymotors.com/Speed...Tray,3455.html
I bent the upper tabs over 90 degrees, with a little Map Gas induced heat, and then had a friend Powder Coat it before bolting it in.
