Let’s talk tools.
Do I need a brake line bender? how about a double flare tool? Anyone recommend certain ones or have a list of tools that are must haves?
Let’s talk tools.
P100DHG’s Gen 3 65 Coupe #138 Build Thread - Order Date: Aug 2018 - Delivered: Feb 2019 -
First Start: May 2020 - First Drive: January 2021 - Instagram @SixtyFive_Daytona
Since no one else responded (tried to give you a break...) I'll give my two cents worth. Brake lines depend on your build plan. The kit comes with multiple sections of steel brake lines and several unions. The brake lines bend easily by hand, curves can be bent around sockets, that sort of thing. It you're not super picky about routing, a little extra here and there, etc. you can do the whole job using the supplied tubing and without any new flares. At the other end of the spectrum would be rigid stainless, few/no unions, etc. Then you need bending tools, a decent flaring tool like this one https://www.eastwood.com/professiona...ring-tool.html, etc. Lots of guys like NiCopp brake line if you want to make your own and don't want to deal with something like stainless. Easy to flare with less elaborate flaring tools. But I'm still a big fan of the Eastwood tool. Ditto the same discussion for fuel lines. Similar decisions to make there, once you settle on the right size for your build. The kit comes with 5/16-inch supply and 1/4-inch return (if needed).
There's a tool list in the build manual. How much more than that you might need again depends on you, e.g. what if any mods you do, your personal build choices, etc.
