Pedal box is in. QUESTION: When the time comes to adjust the brake and clutch switch positions, how far does each pedal have to actuate the white button on the end of each switch unit? Half way? All the way? I'm asking now because even if we bottom out each switch unit on the mount, the white button does not get pressed all the way in. Thought about slightly bending the mount toward each pedal or using a thin washer (or nothing) between the mount and the switch unit in order to set it back further toward the pedal?? BF1134E4-ED70-41F6-8F70-5246D59F6C7B_1_201_a.jpg
