Learning from my mistakes on the passenger side panel (which I'll need to redo). I outlined and cut a rough shape of the driver side panel. Started the application from the back of the panel and worked my way forward. The contours of the panel bent the forward running board area part of the vinyl down and caused a misalignment issue. I managed to salvage it by using lots of heat to stretch a fit. I should have taken pictures mid-application as it looked horrific all bunched together and rolled around itself, its hard to believe it came out better than the passenger side. Side vents are the only thing that came out wrong. No way could I get the material to stretch and fit. About 10 hours to get the side panels mostly done.
Step 1: Outline
Step 2: Cut
Step 3: Apply
And your done!
Special Note: Don't burn yourself
