View Poll Results: Divide the Roadster area into build areas
Voters
29. You may not vote on this poll
  • Yes
    4 13.79%
  • No
    25 86.21%
Results 1 to 17 of 17
Thread: Sub-Divide the Roadster Area
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    I've noticed that the Roadster area of the forum isn't sub-divided into general areas of "build"... Electrical, Brakes, Engine/trans, Body, etc.
    I inquired the moderators, and the response was "there wasn't much interest by the members" (or something along those lines).
    I'm just curious if y'all would like the Roadster area broken up into task-specific areas.
    John D. - Minneapolis 'Burbs
    I'm listening....
    PS Nice sig.
    Division has been tried before (i.e.; 4.6 mod builds, etc.) and it simply doesn't work.
    Senior Member Mike N's Avatar
    Mooresville NC
    If thread starters would be nice enough to put a key word in the subject line it would make searches easier. Quite often the thread subject lines are quite cryptic. David can we somehow have a way of selecting a thread category when starting a thread? Perhaps from a drop down menu. That way we can keep a single forum but be able to filter searches more effectively.
    Mike............
    Mark Eaton's Avatar
    Medford, Oregon
    Quote Originally Posted by Mike N View Post
    I think this is a very good idea
    I'm a no. IMO combined gains a broader audience for responses, which is primary need for those looking for assistance. Subdivide and those looking can find easier, but those with experience aren't seeing the thread to offer a response.
    Aug 2017
    Minneapolis 'Burbs
    Can we make this a "sticky" for the duration?
    I've just found it frustrating that if I'm looking for ideas on "footbox cooling", or "brake line routing" I have to scan through an entire build-thread for one or two posts about it.
    If these topics were in their own area, I could quickly see ALL ideas about the topic.
    Keep up the replies!
    If you are looking for "footbox cooling" try going to google and type
    site:thefactoryfiveforum.com "footbox cooling"
    Coincidentally, you might have a look at my "MKIII Refresh" thread for info on that:
    https://thefactoryfiveforum.com/show...-Mounted/page2
    Also Coincidendally, I discuss brake line routing in my "15th Anniversary" build thread starting on post 18:
    https://thefactoryfiveforum.com/show...V-build-thread
    Tybee Island, GA
    My vote is to keep it all in one spot. I sneak glances here during the day, and get caught up on "all things" roadster when I look at the category. I also learn about things ahead of time even though I haven't gotten to a particular step yet. Several areas would never get visited.
    The search method that David describes works very well for me to find information regarding a topic that I need help with.
    But I do think that Mike N's idea about a drop down at the beginning of the thread is a good idea.
    Videos are at: YouTube Videos
    Senior Member dbo_texas's Avatar
    Feb 2018
    Austin, TX
    I like the idea of a drop-down "tag" for the thread would help when searching. I'm new to the forum and actually asked about why the Roadster section wasn't subdivided into categories like I've seen on some of the other forums. The search tip that Edwardb and David H. suggested using Google search with specific search syntax has been a huge help vs. trying to use the search tool within the forum which doesn't work so great in my opinion. The syntax Edwardb showed me to use is this (and I think it provides the most applicable results): https://thefactoryfiveforum.com /footbox cooling
    Junior Member Venom61's Avatar
    Stratford, CT
    I find it very helpful when the first post in a build thread contains an index. I can't tell you how often I refer to threads like wareaglescott and others' with indexes when I am looking for a quick hint on a topic.
    Senior Member Jdav's Avatar
    ATL GA
    Quote Originally Posted by Venom61 View Post
    I agree, but I also have not put in the effort to go back and index my own build thread - its a lot of work and am very appreciative of Scott for taking that initiative.
    MK4 #9028 - Coyote - TKO600
    Quote Originally Posted by mikeinatlanta View Post
    I agree.
    I tend to look over all the posts under roadster. I will reply if I think I can help, regardless of the topic. I doubt I would bother, if I had to check a half dozen different subject areas. I belonged to a car forum set up like that before, and it grew very tiresome.
    I agree, the search function can be frustrating at times, but still, it is very helpful in narrowing down a search for a particular subject matter.
    If all else fails, just post what it is your dealing with, and wait for the answers.
    Sep 2011
    Minneapolis, MN
    I agree with the sentiment to leave as is. In addition to using the search method described, I will often hit <cntl F> when get to the link I want related to my search, and re-enter the search string, which will take me to the appropriate spots on the page.
    That’s not handy on the phone, but scanning through the page from the top usually has its own benefits, including learning something I didn’t know.
    As a relative newbie I guess I’m both poorly qualified and yet well qualified. How’s that for equivocating! But I like it the way it is. Seems pretty easy to search and find info on what you want.
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    I vote for leave as is as well. David's suggested searching via Google works well. As for other suggestions, yes having a key word in the subject is good or one could have metadata tags that could be selected by the user when creating the thread. This way there remains one forum but if searched on say for "brakes", then all brake threads would appear. This though is only as good as it's used without making it a mandatory selection when creating a thread. Humans tend to be lazy so my guess is many would not select the tag.
    Kyle
    Mar 2017
    columbus ohio
    Two competing thoughts from an old fart that doesn't spend a lot of time on any forums and therefore may not be qualified to even comment.
    We are all time constrained and those of us with demanding lives outside of our automotive affliction need to make good use of our available time. I frequently stumble on a thread that is interesting, but don't have time to read the background (sometimes 25 pages) to really know what has been discussed. I'd like to more easily be able to sort and only look at areas of current interest without having to spend hours filtering.
    Unfiltered perusing frequently causes me to stumble onto something interesting that I didn't know would spark my interest.
    Therefore, I would suggest a system that would allow the reader to select the whole bucket or just a subset as they see fit. So long as the divisions are in place, the consumer can then decide what best suits them on a particular visit. In other words I want it all.
    At my business we refer to this as "The egg laying, milk giving, pig that you can ride" or simply unicorn.
