Results 1 to 12 of 12
Thread: First Start Paul2stl build #9122
    Senior Member Paul2STL's Avatar
    Nov 2012
    Tacoma, WA
    Wink First Start Paul2stl build #9122
    Hopefully this link worked. Not sure how it came out. It took a bit to get the fuel up to the fuel rail and primed. I had a fuel leak just before the I shot the video that I fix so had some air in the line. Once the Coyote idled down it was pretty quit. I didn't show my excitement in the video to much, just not that type of guy, but I was so happy to finally start her. This car is going to be f@#$ing fast. Cant wait for the first go cart.
    https://youtu.be/JmqKSGjywjI
    MKIV #9122 Ordered kit 5/24/17 received kit 8/11/17 MK4 Base kit +,First Start 4/7/18, First Go-Cart 4/22/18, In gelcoat, licensed and driving 8/11/18. Coyote gen2, T-56, 2015 IRS 3.31, 17" Halibrand replicas w/Nitto NT555 G2, Withby Motorcars power brake kit W/Wilwood pedals, 04 Cobra front brakes, 15 Mustang rear brakes with mods, power steering. Paint Jeff Miller Da Bat, Lexus Spectra Blue Mica W/Toyota Silver Sky Metallic strips. Build thread: http://thefactoryfiveforum.com/showt...Paul2STL-Build
    Congratulations! Good luck getting that silly grin off your face any time soon. It gets worse with the first go-cart!
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    congrats! never get tired of seeing first start videos.
    Looks like first and reverse works. Nothing to do now but put it on the ground and go for a ride!
    RR20AC's Avatar
    Puyallup/WA
    Congratulations Paul, Sound awesome. Build is coming together well. Jim
    20th Anniversary MK4 Roadster, #8752, 18 of 20, Delivered 12/03/15, 1st Start 01/28/2017, off to paint 4/13/2017, Forte 351w/ Holley EFI, Forte throttle linkage, TKO 600/Forte Hyd. Clutch, UniSteer Electra Steering, RT's turn Signals, many Breeze parts, Paint by the Jeff Miller. Finished on 10/08/2017. 500 mile inspection on 10/21/2017, 3000 mile inspection on 1/14/19.
    Chino Valley, Arizona
    That’s awesome Paul; congratulations...did see a very slight smile...
    Man You Ford Fellows Love To Show Off!
    Congratulations From The Swamplands Of Louisiana!
    Senior Member cv2065's Avatar
    Dec 2017
    Nice work Bud! Has to be one of the most gratifying feelings one can have after installing everything and cranking up with success!
    Mark Eaton's Avatar
    Medford, Oregon
    You're rocking it!
    Way to go! For me, the sense of relief was so strong, I didn't show much emotion either. Wait till you go-cart. Try not to smile, I dare you.
    Mar 2017
    SW Ontario
    Love to hear the Coyote up and running. Great work.
    Senior Member Duke's Avatar
    Taxachusetts
    Nice work, looking good.
    Nov 2012
    Tacoma, WA
    First Go-Cart of #9122 Roadster
    Here is a video my wife shot and edited. This was after a good break in on the engine and fixed a few leaks . The Speed Hut oil pressure sending unit stopped working. Also I was sent a celsius reading temperature gauge. Guess I’m calling Speed Hut to get replacements. Did get a mil light come on after the break in and few starts. It turned out to be a coolant issue, I’m guessing it was a air pocket in the system since it was a little low. Reset the light and hasn’t came on again after adding some coolant. Other than that has ran smoothly. This thing is freakin fast!! Enjoy the video!
    https://youth.be/EErbusyeYYo
