Putting my questions at the top:
1. Am I forgetting anything? Or am I including stuff I won't actually use (I have the Coyote Fitment Kit + IRS).
2. With the calipers, I was thinking of ordering decals to put Wilwood back on after. Does Wilwood sell them, or just buy aftermarket like these on Amazon?
3. Pedal boxes, for things like the clutch quadrant assembly, should that be painted? POR or PC?
4. What about the Door Latch spacers? I think EdwardB simply attached them before body painting and they got painted.
5. The manual suggests PC for certain parts, yet some seem silly to PC, and are on my POR list, any concern? Like the quadrant stop and switch mount.
I didn't realize how long the engagement with local powder coating places was going to take... After a couple weeks of back and forth, I think I have found the right crew and reasonable price. 20+ years experience, probably take them a week, and between $800-1000 depending on the details of final parts list and such. They also are happy to do my calipers in my accent color for another $200 or so. Seems reasonable.
As I have been going thru this, I have read many other build threads that say "I should have included that on my PC list", so I have tried to do my best to be 1 trip and done, we'll see. Here's the list I compiled of stuff going to the powder coater.
53 panels to Powder Coat:
Part # Description
10551 Footbox Outside Vertical Wall, PS
10554 Footbox Outside Vertical Wall, DS
10853 Footbox Top, PS
10858 Footbox Top Outside Section, DS
10905 Footbox Tunnel Side Vertical Wall, DS
12273 Engine Harness Block Off Plate
12407 Dash Harness Block Off Plate
12806 Transmission Tunnel Front Vertical Wall
13138 Footbox Front Vertical Wall, PS
13139 Footbox Tunnel Side Vertical Wall, PS
14733 Footbox Front Wall Patch Cover, DS
15015 Footbox Top Outside, PS
15523 Footbox Top Inside Section, DS
15802 Wilwood Clutch Blockoff
16061 Footbox Top Inside Cover, DS
16277 Footbox Front Wall Panel, DS
10559 Firewall
10863 F Panel, PS
10864 F Panel, DS
10963 Firewall Extension, PS
13647 Fuse Panel Mount
16274 Coyote 2015 Computer Mount
16484 Coyote 2015 Fuse Panel Mount
B70561 Front Battery Box (Breeze)
B32204 Fan Shroud (Breeze)
RP101 Main Intake Cowl - Nose Opening (Replica Parts)
10560 Trunk Floor, Upper (Front)
12959 Trunk Floor Block Off Plates (x2)
15011 Trunk Outside Wall, DS
15012 Trunk Outside Wall, PS
15222 Trunk Floor, Lower (Rear)
15223 Trunk Side Cover (x2)
RT101 Trunk Drop Box (Russ Thompson)
10557 Cockpit Floor w/Tunnel Wall, DS
10558 Cockpit Floor w/Tunnel Wall, PS
10563 Transmission Tunnel Top
10823 Rear Cockpit Vertical Wall
10906 Transmission Tunnel Rear (U-Joint Access Panel)
12274 Transmission Harness Block Off Plate
12985 Footbox Dropped Floor, DS
13247 Transmission Tunnel Rear Corner, PS
13634 Footbox Dropped Floor, PS
13642 Under Door Lower, PS
13803 Under Door Top, DS
14057 Transmission Tunnel Cover Block Off Plate w/Hole
14582 Under Door Lower, DS
14583 Transmission Tunnel Rear Corner, DS
14584 Under Door Top, PS
15020 Rear Cockpit Corner, DS
15021 Rear Cockpit Corner, PS
RP102 Underdash Filler Panel (Replica Parts)
Notice I am not using certain parts because I am replacing with parts from ReplicaParts, etc. This is mainly just the Nose panels and a couple dash switch mounts.
31 Additional Parts for Powder Coating:
Part # Description
33113 Bracket: Trunk Hinge Mount
15639 Trunk Hinge Arm
14788 Wilwood Brake Light Switch Mount, Steel
16209 Wilwood Pedalbox Mount
16210 Wilwood Pedalbox Rear Mount
13972 Bracket: Gas Strut, 90 deg bent, Short
13451 Frame Adjustment Plate, DS
13452 Arm Support Plate, DS
13520 Arm Support Plate, PS
13946 Hood Mount Plate
14006 Frame Adjustment Plate, PS
15143 Long Arm, DS
15144 Long Arm, PS
25410 Arm: Short
13531 Spacer: 3/16, Steel (Door Latch)
15176 Lower Handle Assembly
15661 Front Body Mount, DS
15662 Front Body Mount, PS
12470 QJ Bent Hook, DS
12471 QJ Bent Hook, PS
16000 IRS Swaybar Mount, DS
16001 IRS Swaybar Mount, PS
23 parts I am planning to simply paint with POR.
Part # Description
13653 Bracket: Brake Line Mount
14495 Fuel Filter Bracket
14689 Braided Brake Line Mount
15170 Bracket: E-Brake Mounting
15431 Accelerator Mount Bracket
60175 Drive Shaft, 31 Spline x10.50
15167 Fixed Gear
15168 Handle to Ratchet Mount
15169 Ratchet Tooth
15016 Fuel Strap Block Off Plate
16258 Clutch Top Travel Switch Mount
16259 Clutch Bottom Travel Switch Mount
16260 Clutch Pedal Switch Mount
16262 Bottom Switch Clutch Quadrant Plate
16122 IRS Center Section
And lastly the 4 splash panels in Dupli-Color Bed Armor.
Thanks again
-Brian
