Red Loctite on the Wilwood DPS6 Front Disc Caliper
Guys,
The Wilwood instructions for the front wheel caliper recommends applying red Loctite when attaching the Wilwood caliper to the Wilwood mounting bracket. Even though the brake pads are inserted after this step, won't there be times in the future when it will be necessary to remove the caliper and won't the red Loctite make this very difficult?
The instructions also require applying red Loctite when attaching the Wilwood caliper mounting bracket to the FFR mounting ears. Is this necessary too.
I would appreciate your comments on this.
Damien
