shark92651
Slightly off-topic but related - If I were to go ahead and shorten the leads and mount the weatherpacks for the lights on all 4 corners, how long should the leads be as they hang off the corners of the frame? Without the body in place I don't want to make the mistake of cutting too short and having to add wire later. Thanks.
I shortened the wires so I didn't have much extra length but enough to get the plug through the mounting holes for connecting/disconnecting the lights. That makes it easier to get the plugs mated. I also kept the wire length and pin wiring the same on all the lights so they were interchangeable.
