Thanks Jeff and for the pics. I have the FFR 4 into 4 headers.With the running changes FFR has made to the driver's side it's just about as good as it gets unless you're fighting for that last millimeter. Passenger side depends; 4 into 4 headers or shorties and J pipes? I have both in the shop presently and just shot these looking down at the PS inside front corner.
That's about 1 finger between the header and footbox corner with the 4 into 4s. Not much ground to gain there in my opinion, at least for the effort it would require. There is room to go forward with the shorties but doing so would kind of paint you into a box if you ever had thoughts of upgrading to the full length headers.
Remember Michael, right out of the box the Mk4 passenger side is significantly larger than what you've experienced from the right hand seats in Sten, Dan and Craig's earlier cars.
I had come to the conclusion that it was not needed but then Jazzman told me this was his #1 regret... so I started to question the conclusion I came to.
