Results 1 to 13 of 13
Thread: Brake reservoir?
    Senior Member John T's Avatar
    Feb 2018
    Springfield, Missouri
    Brake reservoir?
    I'm using three of the FFR supplied chrome reservoirs (One supplied with the complete kit and two purchased). One is for the clutch, one for the front brakes and one for the rear brakes. My question is will I be able to put them on the square steel tube in front of the DS foot box and have plenty of clearance?
    Jan 2015
    Quote Originally Posted by John T View Post
    I made a alum plate attached to upper 1/2 square tube drivers side. Will send a picture if I can figure it out.
    Jan 2015
    I made a pair of brackets to hold my Triple Reservoir on the square tubes.
    It mounts on the upper and lower to reduce vibration issues and can be viewed between 20-35 seconds into the video.
    https://youtu.be/PCngiKoopkA
    Remember that the reservoirs MUST be higher than your master cylinders since we all know that fluids like to flow down hill.
    Also, be very cognoscente of the location so that they don't interfere with the body or hood.
    Good Luck & Wrench On Brother, Wrench On!
    I mounted the same 3 reservoirs on an alum angle. Drilling for 3 is critical to maintain equal spacing and height. With the mounting screws going into the bottom of the square frame tube, I am able to space it down with shims, if it interferes with the body. The top of the reservoirs is about the only thing higher than the master cylinders, thus the reservoirs need to be kept full. My reservoirs are the old style and the caps are unvented. I have a source for some small check valves, that I hope are adaptable to the caps.
    Feb 2018
    Thanks all of you. I was wondering if aluminum would work as well a a steel plate. GoDadGo, did you fasten your bracket top and bottom or just top?
    Aluminum works fine. This bracket is 1/8" alum.
    The body overlaps the 3/4" tube so you will want to mount the reservoirs so there is 3/4" - 1" spacing between the edge of the caps and the 3/4" tube. Mine were a little too close to the body so I spaced them out a bit further after this photo was taken.
    Keep the top of the caps flush or within 1/4" of the top of the 3/4" tube and you'll be good.
  8. Thanks SuperFlyBriBri thanked for this post
    Ancaster, Ontario
    Not to put a damper on things but I had that style of reservoir and changed them out to the larger diameter, newer style ones that have a circumference mounting ring. With the previous ones the outlet elbows pointed in all directions when I tightened them sufficiently to stop the leaks. The same happened with the newer ones but they can be rotated to align the elbows all in the same direction.
  10. #9
    Kearney Nebraska
    I really like these, they look like something that came out of a car from the 60's. Were did you get them?
    Serial #9158
  11. #10
    Feb 2018
    Quote Originally Posted by Joecobr View Post
    I have the new ones also. The rings take up a little more space pushing the bracket toward the 20" limit of the radiator mount. The rings can be overlapped since the reservoirs can be leveled inside the rings.
  12. #11
    Nov 2023
    Erie, PA
    Does anyone know the size of the cap? I want to put a cap on to pressurize the line to bleed them.
    Thanks all!!
    Craig M
  13. #12
    Dec 2021
    Flagstaff, AZ
    Nov 2023
    Erie, PA
    thanks Steve,
    I was looking for the FF reservoirs.
    Craig M
