Results 1 to 7 of 7
Thread: 1965-427 Cobra Factory Five spec racer for sale
    Jul 2019
    Keith Craft Racing Engine, 427 aluminum Genesis block stroked to 482 c.i., 10.6:1, Ported Dove 428S Scat crank, H beam rods, JE pistons, Comp Cam,
    DaVinci 950 carb, 600ft. lbs. torque-630 horsepower
    TKO 11 5 speed trans., Independent rear suspension-Auburn diff, 3.55 posi.
    4 wheel Cobra disc brake kit w/upgrades rotors, Cobra R wheels w/Nitto 555ZR tires,
    complete tube chassis and roll cage, suspension fully tuned, weighs 2450 lbs. (approx. 4.0 lbs. per H.P.
    Jeff Miller Paint w/Silver powder coated chassis
    Engine bay cockpit fire suppression system
    Owned by David and Lori Chase
    $65,00020170502_145129 (450x800).jpg20170527_092213 (800x450).jpg20170502_145629 (800x450).jpg20170502_145727 (800x450).jpg20170502_145700 (800x450).jpg20170502_145647 (800x450).jpg
    Jul 2019
    Sorry pictures are upside down. Don't know why that happened and can't seem to fix it.
    I downloaded and re-uploaded them for you. Best of luck with the sale!
    mburger's Avatar
    Punta Gorda FL
    I think the pictures are ok, but I'm upside down.
    Mark
    Member bsnyder's Avatar
    Spanaway WA
    Where are you located?
    Jul 2019
    Ronald WA
    Jul 2019
    if you open the picture and then click the picture again it should flip it so you don't have to stand on your head
