Likes Likes:  12
Results 1 to 30 of 30
Thread: Cold Air Box Fabrication
    Time to test my fabrication skills. I plan to (try to) fabricate this cold air box from .063 6061 aluminum sheet. Sides will be attached via brazing (I hope). Sprayed one panel with Dykem tonight and will begin laying out the dimension for the holes.
    Dimensions plotted
    Ready to start
    Senior Member Jetfuel's Avatar
    Aug 2018
    Heck yeah...give it world...we will be watching this project
    Jet
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    4-sure. Will be a jewel if you match or beat that picture.
    Redding - great place to live. In 2007 I was out there several times installing radiology software at Advanced Imaging - when Dr. Hecht was building and opening his center. Took my wife along on the last trip to see the sights like your cool glass bridge. Next we went over the hill, stopped in Eureka (toking center of the world?), rode the "skunk train" and took in the Avenue of Giants, etc.
    All dimensions laid out on a sheet of .063 6061-T6 aluminum. Checked and rechecked, and checked again. Now waiting for a special size hole cutter for the air horn holes. Time to make some chips!
    Received my new carbide tip 2.125 hole cutter for the air horns. Cuts like a hot knofe through butter. Expensive but so much better than the **** at Home Depot or Lowes
    Nearly finished with the base plate. Air horn holes and fuel inlet reliefs cut. Next are the access holes for the needles and jets.
  7. Likes Higgybulin, cgundermann liked this post
    Base plate complete. Assessing rake for side pieces
  9. Likes Straversi liked this post
  10. #8
    Aug 2018
    That looks really cool, and as you assess the side pieces may I suggest slope up and fallow the string hood lines and round off the forward corners....just like post 1
    I could be wrong....but that's why we're here
    Jet
  11. #9
    I plan to
  12. #10
    Aug 2018
    Yeah but with your own spin....shallow grooves milled into the side walls will set it off.".just saying
    Jet....
  13. #11
    First shot at making the sides came up close but failed. Bent one corner a tad short. Time for attempt #2
  14. #12
    Success!
    Time to weld
  15. Likes Higgybulin liked this post
  16. #13
    Port Charlotte, FL
    Nice work Bill!!!
    Henry
  17. #14
    Lilburn, GA
    Nice!
  18. #15
    I remade the sides. I raised the front 1-1/2”. Now it more closely resembles the one I copied and better fits under the hood. There’s a small gap in one corner but I think it can be welded closed.
    [URL=http://imgbox.com/q5uG35vB][/URL
  19. #16
    Dec 2017
    SW Fl
    Nice job! I'll bet those carbs will thank you for that fresh air... Anthony
  20. #17
    All set to take to the welder tomorrow
  21. Likes Straversi liked this post
  22. #18
    I got my cold air box back from the welder. Disappointed in the quality of the welds. He also tacked the underside which I didn’t want. I spent the first day using a flap,wheel on my grinder to blend the welds on the outside .
  23. Likes SSNK4US liked this post
  24. #19
    deleted.
  25. #20
    I added notches to clear the fuel inlet fittings
  26. #21
    Finished sanding the inside. Time for the outside
  27. #22
    All finished and installed. Polished the air horns while I was at it.
  28. #23
    Nov 2019
    Jacksonville, Florida
    Very impressive.
    I need to learn how to do that.
  29. Likes 2FAST4U liked this post
  30. #24
    Beautiful!
  31. Likes 2FAST4U liked this post
  32. #25
    Chino Valley, Arizona
    Very, very cool!
  33. Likes 2FAST4U liked this post
  34. #26
    Jan 2020
    Excellent work! From what I can tell this is the engine setup I would do. Can you give more details on the engine and carb specs? Did you build the engine up yourself? I have built some Triumph and MG engines and would be a little lacking (OK...a lot lacking) in having any experience on what the best components would be for one of these thunderous engines. I know Webers and have good experience getting them to sing together, but the rest...ugh
  35. Likes Jwymore liked this post
  36. #27
    Block is 90 roller block. 030 over, squared, and decked.
    Crank is Scat forged steel stroker.
    Probe industries forged I-beam rods, polished, full floating
    Probe industries forged aluminum pistons for TW heads, domed, sides coated with Teflon
    Probe industries lightweight steel wrist pins
    Mains align honed
    Everything balanced
    Comp Cams Pro Magnum roller rockers
    Hydraulic roller cam (.571/.587 lift, 112 LSA)
    Aviad reproduction original oil pan
    Weber 48 IDA carbs modified for low speed driving
    Blue Thunder reproduction Weber manifold
    Twisted Wedge aluminum heads (2.02/1.60, 65cc chambers)
    Heads and intake manifold port matched and polished
    Size 60 weber jets
    Jim inglese fuel/water inlet with correct hoses and clamps
    Stamped steel valve covers modified to original look
    Period correct breather caps and decals
    I have a total of $14,045 in the engine alone. Yes, I built the engine myself.
  37. Likes SSNK4US, Jwymore liked this post
  38. #28
    Jan 2020
    Thanks for the response!!! Great info.
  39. #29
    Mar 2020
    These specs are pretty much what I am looking to do for my Daytona Coupe. Have you had this on the dyno? I'm guessing something in the 425 Hp range? The step by step on the air box is very helpful too as I will at some point be fabricating one.
  40. #30
    No dyno
