Results 1 to 7 of 7
Thread: E Brake cable question
    Jan 2013
    Hi All,
    I hope the FF community is faring well during these troubled times.
    I ordered the Wilwood brake upgrade with my kit back in 2013, there is a box labeled "Wilwood solid axle brake line parts," and that box lists and has the "Emergency Brake Cables."
    They appear to be the correct length, but I don't see listed or find a spring clip or C clip for securing the metal end of the cable to the mounting hole on the caliper? Any ideas or advice is appreciated.
    Mark IV #8008, 2013 Coyote 5.0, TKO600, 8.8 Moser 3 link
    I haven't personally worked w/ the Wilwoods but I think you will find that once the cables are adjusted properly and operating, that outer sleeve can't really go anywhere. I am sure others will chime in soon.
    Jul 2019
    Portsmouth. NH
    I agree with you, I couldn't find the clips either. Interested in what people will say
    FFR Roadster: Received 11/18/19: BluePrint 427w, TKO600, Glenn's performance fuel system, IRS, Wilwood Brakes, Sniper XFlow and many more
    The cables don't come with any clips and many will tell you that they aren't needed. Needed or not, I added e-clips to mine. I don't recall the specific size I used, but I like having these sorts of parts in various sizes in my tool box, so I bought this assortment:
    Jan 2013
    Thanks all for chiming in. I reached out to Factory Five also, and Dan came back quickly here was his response:
    Hi John, only friction holds the ebrake cables in place, and it is common to need to open up the hole in the caliper slightly for the cable end to fit well.
    Thank you
    Fairfax Station VA
    Check out post #5 by Richard Oben at https://thefactoryfiveforum.com/show...-E-brake-cable to understand why they aren’t necessary on our cars.
    MK IV Roadster #8631
  7. Thanks Richard Oben thanked for this post
    Jan 2013
    Thanks John, I tried searching for post on this subject, I guess I need to improve my search skills.
