Thanks Thanks:  61
Likes Likes:  49
Results 1 to 40 of 134
Thread: Graduation of FFR #8692 20th Anniversary MK4 #9 of 20
Threaded View
    Senior Member Paul Mischenko's Avatar
    Nov 2015
    Westchester, NY
    Hi Guys,
    Finally after a 4 year build its time to graduate #8692, I'm # 9 of 20 from the 20th Anniversary MK4 kit. Wanted to thank everyone who takes the time to post ideas and their build threads to this forum. Really was a huge help during my build.
    I wanted to give a special thanks to Edward b (Paul Borrow) who's build log was my go to during my entire build not to mention all the help he provided along the way with my hundreds of questions. I also wanted to thank Tony Zullo from FFR, Tony was also a go to resource helping me along the way. Thanks so much guys for all your help.
    Details of the build:
    Kit purchased Aug 2015, completed July 2019
    Options/Modifications:
    Custom Stainless-Steel Brake and Fuel lines
    All uncoated Aluminum Panels powder coated Tiger Drylac Glimmer to match frame
    FF Metal - Trunk Battery Box
    FF Metal - .090” FireWall
    FF Metal - .060” Transmission Tunnel Top
    CNC Triple Brake & Clutch Reservoirs
    Breeze Fan Shroud powder coated Tiger Drylac Glimmer to match frame
    Breeze Aero locking fuel cap
    Breeze stainless steel hood prop rod kit
    Breeze billet aluminum side-view mirrors – driver & passenger
    Breeze engine compartment battery mounting kit – powder coated Tiger Drylac Glimmer
    Breeze radiator cowl cover – powder coated Tiger Drylac Glimmer to match frame
    Tangent Technologies Blind Roll Bar Kits
    Lodestone Billet Work polished brake and power steering hose clamps
    Moreland Hose custom stainless-steel fuel hoses
    Watson Streetworks Billet Dash LED indicator lights
    Gas N polished stainless-steel side pipes & 4 into 4 stainless steel headers
    Drummer Mike mirror polished stainless-steel side pipe heat shields
    Herb Frazer custom interior leather matched door panels
    Fortes Mechanical Throttle Linkage
    Acton Cobra Custom FFR Aluminum Dash with Custom Glovebox
    Dark Water Customs rear mirror bracket
    Dark Water Aluminum Door Sills – Mirror Polished
    Eddie Marine polished dash grab handle
    Whitby Motors stainless steel windshield posts
    ********** Front Bumper Grommets
    ********** Wiper Arms
    ********** Cobra Nose & Deck Emblems
    ********** Shifter Handle 427 T5
    Lucas Switches
    Replica Parts under-dash filler panel
    Replica Parts Seat Belt Trim plates
    Replica Parts Russ Thompson Turn Signal Bezel
    Replica Parts Billet aluminum windshield post trim plates
    Replica Parts Roadster Firewall support
    Replica Parts Shifter Trim Ring
    Fortes hydraulic clutch kit
    SuperBright Tail Light LED’s
    Metco Motorsport driveshaft safety loop – Powder Coated Tiger Drylac Glimmer to match frame
    Hudson Valley Interiors – leather work – Dash/Transmission covering, carpet binding, shifter & e-brake boots. Transmission cover and shifter boot stitching Navy Blue to match body color.
    Twisted Shifter – 2” chrome shifter knob
    Billet Badges – Custom Steering Wheel Hub Badge
    Boig Radiator Tubes
    Jet Hot - Silver Polish Ceramic coating: stainless steel headers & Boig radiator tubes
    Jegs mirror polished stainless steel 52 oz radiator overflow canister
    Triple Chrome Plating: hood hinges and brackets, door hinges, trunk brackets
    Factory Five Trunk Strut Kit – mirror polished
    Factory Five Wind Wings Kit
    Factory Five Roll Bar Trim Rings and Grommets
    Factory Five Sun Visors
    Factory Five Vintage Wiper Kit
    Factory Five Trunk Carpet Kit
    Factory Five Passenger Roll Bar
    Russ Thompson Turn Signal System
    Russ Thompson FFR Throttle Pedal
    Russ Thompson Dead Pedal
    Russ Thompson Trunk Drop Box
    Custom Stainless Steel Brake Duct & Oil Cooler covers
    Custom Stainless Steel Radiator Grill
    Painless Classic Braid
    XPEL paint protection – rear wheel well, bottom from wheel well, bottom front spoiler
    Drivetrain:
    Roush 427 SR 351W polished, Dyno 516 HP, 527 ft lbs. torque at flywheel
    351 W block, valve covers, air filter, MSD box & coil all painted to match body
    Tremec TKO 600 5-speed with upgraded syncros, 0.64 final drive
    Quicktime Bellhousing
    McLeod billet steel flywheel
    McLeod Super Street Pro Clutch
    Interior:
    Custom Speedhut instruments with GPS speedometer
    Custom Competition dash covered in leather
    JL Audio hidden stereo w Bluetooth receiver
    Removable transmission cover with matching leather covering w dark blue (body match) stitching
    Custom Billet Badges steering wheel hub badge
    Matching leather door panels, dash, transmission cover, shifter boot, e-brake boot and carpet binding
    Cockpit coated with Lizard Skin Sound and Heat Insulation
    Body:
    Bodywork and paint by Ron Randal Metalmorphous
    Color is a Midnight Metallic Blue – white stripe is a match of the white engine panels in our 20th Anniversary Kit
    Show quality paint
    3m undercoating
    Front and Rear Elephant ears removable and clear undercoated
    Front Suspension:
    FFR 2-piece spindles and LCA’s
    Koni 8212 double adjustable coilovers
    Power Steering with custom Jones racing Pump – painted to match body – canister polished
    Swaybar
    Rear Suspension:
    IRS with 2015 Mustang differential, limited slip, 3.55 ratio, modified IRS knuckles and hubs.
    FFR UCA’s and LCA’s
    Driveshaft Shop driveshaft and CV axles
    Swaybar
    Driveshaft Loop – Powder coated to match frame
    A-Frame Transmission support powder coated to match frame
    Brakes:
    Willwood 6 piston 12.88 dia front, 4 piston 12.88 dia rear, separate parking brake caliper
    Wheels & Tires
    FFR Hildebrand style 18x9, 18x11 5-lug
    245/40 front, 315/30 rear, BF Goodrich Rival S
  2. Likes Grizzly, Christopher liked this post
