9
Congratulations on your order. You're in for an excellent adventure. Your story of starting near the end of your career is similar to mine. Except I didn't stop after retirement. I know. I have a problem... Some comments about your list:
- Strongly suggest not going with J-pipes. You have a nice higher level build going there and you'll be much happier with headers versus the more economical J-pipes. Both performance and durability. Factory Five headers with the ball flanges are excellent. Or you could go Gas-N along with the suggested Gas-N side pipes. You'll get opinions about each.
- You might want to think about ordering your engine now too. DART based products currently have a long lead time.
- The black vinyl Roadster seats are fine IMO. The leather version (if that's what you're thinking of for an upgrade) are nice. But not a huge upgrade IMO. I've had both.
- Yes you need the driveshaft adapter.
- Yes you can delete gauges for a credit. Nearly everything can be deleted for a credit. Just don't expect a fortune. I suspect the amount is something around their cost. Not what they sell for.
- Not aware that FF sells a heater/A-C system for the Roadster. Guys have squeezed them in. But not sure the details. Good question to keep asking.
- I'd recommend sourcing your EFI in-tank components elsewhere. They're very common, widely available, lots of choices, and likely cheaper. Depending on the engine you end up with, you may find the kit provided fuel lines are marginal. If you change them, the kit provided in-tank components may not be your best choice.
- I'd also recommend adding the 16808 Trunk Gas Strut Kit. A good deal at $50.00 and will keep the trunk lid from falling on your head. Just happen to know that. Their floor mats are great quality, fit perfectly, and protect the carpet which is fine for everywhere else but will wear quickly on the floors if not protected. Most also do wind wings and visors. But that's a personal choice. Like most everything.
Good luck!
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
