Results 1 to 23 of 23
Thread: Boig Motorsports Cooling Tubes Now Available!
    Boig Motorsports's Avatar
    These rugged, race proven cooling tubes are mandrel bent, with each end beaded to firmly grip the clamped hoses. They have been beautifully ceramic powder coated internally and externally for increased longevity. The come with custom fitted top quality hoses designed for the FFR Afco radiator and your engine application.
Their robust designs, developed from years of racing applications, combined with the beautiful ceramic powder coating have brought some customers to consider them “engine jewelry.”
    They replace “one size fits all” corrugated hoses which can fracture while the rubber adapters can crack, leak, and slip off the radiator.
    These cooling tube assemblies are a clean, custom fit, easy to install, and will provide you with years of worry free driving.
    Cooling tube assemblies are available for the following engine installations:
    #70706 - Upper Radiator and Tube Forward Kit for 302 or 351Windsor with Afco Radiator - Includes mandrel bent and beaded silver ceramic powder coated 1-1/2” OD steel tube into 1-1/2” ID coupler hoses. This kit replaces the corrugated tubing between your radiator filler T and the Afco radiator inlet.
    #70690 - 302 or 351 Windsor upper to Afco Radiator with Filler Neck - 1-1/2” steel tube is beaded on each end. Pressure cap fitting is welded to the tube.
    #70688 - Lower Radiator Hose and Tube Kit for 302 and 351 Windsor in Factory Five Roadster with Afco Raditor
    302 and 351W Afco radiator lower
    Click here to visit our website and order.
    Boig Motorsports Parts
    View our 818 Exhaust and Cooling Tubes!
    View our Roadster, Type 65 Coupe, and Hot Rod Cooling Tubes!
    View our Quiet Pipes Side Pipe Kits for Roadsters!
    #70700 - Lower Radiator Hose and Tube Kit for Coyote in Roadster with Afco Radiator - 1-1/2” OD steel tube, mandrel bent, beaded, and silver ceramic powder coated inside and out.
    #70617 - FE Big Block Lower Radiator Hose and Tube Kit for Mk1 - Mk2 Roadster - Lower radiator hose with Afco radiator uses 1-3/4” OD mandrel bent and beaded silver ceramic powder coated steel tube with front and rear hoses.
    #70689 - Lower Radiator Hose and Tube Kit for FFR Type 65 Coupe - Equipped with either 302 or 351W engines and FFR/Griffin Radiator - 1-3/4” steel tube is mandrel bent, beaded on each end, and beautifully ceramic powder coated internally and externally.
    Coming Soon - FFR Type 65 Coupe Upper Hose and Tube kit with 302 or 351W Engines!
    #70704 - Hot Rod with 5.0L Coyote at the Radiator
    Top View, Hot Rod lower hose at the block.
    Senior Member DaleG's Avatar
    Mar 2013
    Nice products.
    Chino Valley, Arizona
    Very cool! Wish I hadn't already did mine...
    Port Charlotte, FL
    I have this setup on both my Coyote powered Roadster and my 818 and highly recommend both setups.
    Henry
    Member Blue Classic's Avatar
    Vero Beach, Florida
    These cooling tubes and hoses are top quality and finish. I've had them on my Roadster for 2 years.
    Senior Member Raceral's Avatar
    Stoneville NC
    This is the new style radiator. I am using a FE motor. Do you have a kit for my setup.
    [/URL]
    [/URL]
    Al Adkins
    Certified "Kool Aid" drinker
    Mar 2013
    Medway, MA
    Couple of things on that Al.
    - We have not done an FE with the new FFR radiator with the angled outlet. We did find for the Windsor Lower Hose and Tube kit that the exact same parts fit with the new angled outlet jut by rotating the tube and the front hose.
    - We've had conflicting feedback on the FE lower kit which was developed on a MkII which had a higher x-member than the Mk3-3.1.4. One customer said it did not fit his Mk3 but others have used it successfully.
    Boig is eager to work with you on this. We could start with the usual FE lower kit order with the understanding that it would probably need to be mocked up and photographed by you and Boig would use that information to make a custom configuration for you to test before getting to a final configuration.
    Stoneville NC
    Great, let me get a little closer to getting the rest of the bugs worked out and I will get back with you.
    Al Adkins
    Mar 2013
    Medway, MA
    Breeze has just added the Lower Hose and Tube Kit for Coyote in Roadster with the new FFR Radiator, Part Number 70744. Photo to be loaded soon.
    http://www.breezeautomotive.com/deta...p?prod_id=1136
    Ohio
    I have an Mk4 with the new angled outlet radiator and the added interference of a sway bar. Engine is a Windsor 427 (351). Do you have anything for this application? Have the upper hose already. Just need the lower hose.
    Mar 2013
    Medway, MA
    We recently checked this and confirmed our lower hose and tube kits clear the FFR sway bar.
    Do you sell anything for GTM's with LS engines?
    Do you offer anything for 460 set up?
    Stoneville NC
    Any FE upgrades yet... I'm done and if you want to send me a kit I will try it and see what needs to be modified if you think there may be a market
    Al Adkins
    North Dallas
    Do these fit the MK4 coyote with the newest radiator? The link to breeze part doesn’t show the part?
    Jason
    Yes, BMS-104 is the part you want!
    We have brought sales in-house. Part described, and you can order on boigmotorsports.com
    Senior Member chrisarella's Avatar
    Clearwater, FL
    No upper hose for the MK4 coyote?
    Mark IV Roadster #7679
    Coyote 5.0, T56, Hydraulic Clutch, IRS, Torsen Diff, Wilwoods, Hydraboost, ABS Power Brakes, Power Steering, & tons more extras.
    Sorry chrisarella, we make the lower hose assembly, not the upper. Many builders use the Ford hose that comes with the crate Coyote motor, and splice a Dorman filler inline.
    Clearwater, FL
    Sounds good Bob. Thanks.
    Clearwater, FL
    Are you still offering the #70700 Lower Radiator Hose and Tube Kit for Coyote in Roadster with Afco Radiator?
    I have the original Afco radiator from 2012 (not the new one that BMS-104 fits).
    Senior Member dpariso's Avatar
    Beach Park, IL
    got anything for a 4.6L?
