Factory Five MK IV Roadster – base kit delivered 08/2015
Non donor build
3 Link suspension
Moser 8.8 rear end
Cobra 11.65 rear brakes
All new braided steel brake lines
Mustang gt front brakes
Sn 95 spindles
Tubular control arms
Whitby power brake kit
Power steering
Ron Francis Wiring Harness
Breeze accelerator pedal
Dual breeze 1 ¾” stainless rollbars – polished
North Race cars air conditioning & heat
LED rectangle tail lights & appropriate body work.
********** side vents
Breeze fan shroud
Breeze oil cooler and brake duct screens
Pegasus SS wire mess radiator protector
Speedhut gauges with gps speedometer
Driver seat sliders
Dropped trunk sheet metal
Breeze cubby
Hurst Line lock
Electric vacuum pump for power brakes
Wind wings & visors
Fully insulated
Inside of body coated with bedliner
Engine:
Full custom 347 small block ford built by FTM performance
Scat forged crankshaft and rods
JE forged pistons 10:1 compression
Custom hydraulic roller cam 233/242 duration, .602/.612 lift on 112 LSA
AFR 195 Renegade Cylinder Heads
Billet flywheel & Balancer
Centerforce dual friction clutch assembly
Lakewood explosion proof bellhousing
Driveshaft loop
8 stack fuel injection – Holley HP ECU – 39 lb injectors
DUI distributor – crane HI6S ignition box-accel coil- DUI live wire plug wires
March underdrive pulleys
Chrome 100 amp alternator
Chrome A/C compressor
Polished SS high capacity power steering reservoir
Engine dyno tested at 516 HP @ 6500 rpm, 464 ft. lbs. of torque at 5200 rpm.
Extra bells and whistles:
Engine Knock sensor
Electronic warning/guardian system for temp, oil pressure and fuel pressure – red warning light
Programmable primary rev limiter
Programmable shift light mounted in dash
Electronic/programmable launch control system which offers the following features:
* Programmable staging 2nd rev limiter activated by clutch
* Programmable timer activated 3rd rev limiter to limit tire spin at initial launch for a specified
time.
*Programmable timer that retards timing and reintroduces it at a defined rate after rev limiter
expires to additionally control tire spin.
Transmission
All new Astro Performance A5 (T5) with midshift tail shaft
Super alloy gears with 2.95 first gear and .64 overdrive gear.
Paint
Painted by Hill Country Rod Shop – Lance Liscum, located in Kingsland Texas
Color is Lexus Ultrasonic Blue Mica 2.0 - 5 stage paint. Cut up to 5000 grit and polished.
Stripes are Ford white pearl
