Results 1 to 40 of 81
Thread: Garage Refresh Completed. Bring on the Coupe!
Threaded View
  1. #9
    As a mentioned in the first post, I need my garage workshop to be ready before the Coupe is delivered. Drywall repair, painting, and new lighting are all finally done. My new Bendpak XPR-10S-LP 2-post lift arrived at the freight terminal and I picked it up there. All 1800 lbs. SE to the rescue again. I was able to take the pallet apart and pick it out of the trailer one piece at a time.
    Completed the pre-assembly and staged for raising.
    Three of my good buddies from the local Cobra club came over and the four of us were able to get the columns standing and the bridge in place. Wasn't too hard with enough help. Surprisingly, getting the bridge up and installed was the hardest part.
    With everything positioned, drilled the twelve 3/4-inch holes in the concrete and set the anchors. Confirmed the garage floor as just over 5 inches thick (lift spec calls for minimum 4 inches) and VERY hard. The installation is very solid. Then installed my RaceDeck flooring. Today I get the last pieces in, not showing in this picture.
    Next up is to run the 220V power and complete the lift assembly. Then hang and hook up my new heater. Some smaller details after that but making good progress. Most of October is going to be taken up with family stuff and travel. But I should be ready in time.
