Thanks Thanks:  20
Likes Likes:  59
Results 1 to 40 of 482
Thread: Shark92651's MK4 Coyote Build #9327 - Graduated!!
Threaded View
  1. #7
    Lilburn, GA
    I am a little unsure about the area Ducky is pointing at on that oil pan. Maybe they changed the design some. Completely different from where Paul determined his dipstick was hitting. Maybe he can chime in with his photo as well.
    After reading that there was an issue, I installed the pan (before modification), only installing a few bolts (loosely) on the opposite side of the dip stick. I lifted the pan an inch or so and pushed the dip stick in until it hit. Seeing where it touched, I marked it with a sharpie. Had to remove the pan to mark it. I re-installed to verify, then drilled. The hole looks slightly off center in the pic. That's due to the fact I had to lift so much to take the pic. Looked better with a minimal crack to peak through. See pic
    NOTE: I also turned the dip stick 180 degrees to verify it didn't have a bend and would hang up if installed 180 out.
